Split Pipe That Connects To Expansion Bottle
cooling water pipe
7 replies to this topic
#1 Stocky
Stocky
  • 35 posts
Posted 25 June 2016 - 07:45 PM
 Hi Guys,
found a leak coming from the pipe that leads up and connects to the expansion bottle. I have uploaded a pic. Does anyone know what this is call and if it can be replaced.
Cheers.
  • Attached File  leak.png   327.73KB   5 downloads
#2 Nev
Posted 25 June 2016 - 08:08 PM
Hmm, that looks like it going into one of those nasty plastic T-connectors. Not sure what to do about that, might need to replace the whole thing with a second hand part.
#3 vxt5
vxt5
  • 199 posts
Posted 25 June 2016 - 08:10 PM
Cant you cut it out and replace with an aluminium t connector? Bit cowboy but should do the job.. Sent from my SM-G928F using Tapatalk
#4 Stocky
Stocky
  • 35 posts
 Hi Guys,
found a leak coming from the pipe that leads up and connects to the expansion bottle. I have uploaded a pic. Does anyone know what this is called and if it can be replaced.
Cheers.
#5 Stocky
Stocky
  • 35 posts
Posted 25 June 2016 - 08:23 PM
Ah ok, Where would I get one from?
#6 Stocky
Stocky
  • 35 posts
Posted 26 June 2016 - 11:11 AM
Thank you. would you mind recommending the part please? I'm actually very novice and don't know where to start lol.
#7 hairy
hairy
    Moonlander
  • 6,028 posts
Posted 26 June 2016 - 12:17 PM
Part numbers here: http://www.speedster...td.)/index.html
#8 Nev
Posted 26 June 2016 - 12:43 PM
You could buy a second hand replacement - Lizp on here might have one.
Also tagged with one or more of these keywords: cooling, water, pipe
