Looks like the inner CV boot has split, crap all over the gearbox:
I hear you can use a Kia part, anybody know more about this?
Posted 27 June 2016 - 07:52 AM
Posted 27 June 2016 - 07:59 AM
Posted 27 June 2016 - 10:00 AM
Posted 27 June 2016 - 12:31 PM
Posted 27 June 2016 - 01:12 PM
FCB 2832 was the Sedona number I ordered, so yes - looks like it.
Mine has been on a good few years with no issues.
There's even a "how to guide" on here. The grease that came out with the old bearings is the worst stuff ever made; I still keep finding it behind my ears, in my armpits, under my foreskin etc... so wear gloves and have plenty of paper towels ready when you do it.
Posted 27 June 2016 - 01:35 PM
Much appreciated
Posted 04 July 2016 - 07:17 AM
Don't use the grease from the kia kit. It will boil. Get proper greace.
What would you recommend?
Posted 04 July 2016 - 09:00 AM
Standard vauxhall grease seems good enough, so i would carefully say anything but the grease from the kia kit.
That litterally went liquid and poored out my cv. (cv was almost empty, but still in 1 piece)
Posted 04 July 2016 - 10:20 AM
Posted 04 July 2016 - 02:14 PM
While you're replacing the boot check for play/wear. After mine split (at Brands Hatch) I replaced the boot but then had a strange vibration when on track. It turned out to be the CV joint had too much play in it but it took me a few (ruined) track days to diagnose the problem as it only caused issue when hot.
Interesting. I think mine's been split a while, haven't noticed any vibration so far. For the sake of £25 and (hopefully) an afternoon's work I'll just replace the boot seeing as my MOT is this month.
Posted 04 July 2016 - 04:30 PM
If you track the car, it's also advised to put in a little breather (wd40 straw on the smaller section) to let the hot air out.
Edited by smiley, 04 July 2016 - 04:31 PM.
Posted 11 July 2016 - 07:21 AM
Fitted this weekend. Messy, difficult job but I'm so glad I saved the labour and learnt to DIY. Steps if anyone's interested:
Brake pads out, disk off, caliper out the way.
Undo Toe link from hub.
Undo lower balljoint, split.
Take off boot clips, pull to expose joint.
Take out "clip" then pull out joint.
Use LOTS of rag to clean.
Circlip off end of joint, tap off "gear"
Take old boot off and replace
Regrease.
Reassemble.
Posted 11 July 2016 - 09:55 AM
Does the grease not also exit through the straw?
Posted 11 July 2016 - 10:37 AM
Centrigufal force throws the grease towards to wide section of the cv boot. Hence putting the straw at the narrow section.
The trick is also pretty old.
http://www.pistonhea...sp?h=0&t=580497
Edited by smiley, 11 July 2016 - 10:40 AM.
Posted 11 July 2016 - 12:37 PM
Ah. Science is involved!
You could even fit it with a small whistle to produce an amusing noise whenever the boot contracts and expands, if you felt so inclined.
Posted 11 May 2020 - 09:26 PM
Posted 12 May 2020 - 06:54 AM
Product Code: 656900080 is a quick way to get the boots cheap from euro car parts with one of their discount codes, only £13. The inner and out look the same size but having not fitted this part to the outer I can't be sure.
Posted 12 May 2020 - 11:28 AM
I can't find exact product details on that partnumber, but keep in mind when cheap, they often are the plastic edition, and not the rubber one.
Plastic may be good for heat, but not so good at difficult angles. (like our left inner side)
