Cv Boot Split - Where To Buy?
36 replies to this topic
#21 gaffer1986
gaffer1986
  • 4,408 posts
Posted 12 May 2020 - 11:31 AM
They made by GKN who I believe supply boots and other components to many car manufacturers. I didn't even know you could get plastic boots?
#22 smiley
Posted 12 May 2020 - 11:59 AM
I learned that the hard way also.
#23 gaffer1986
gaffer1986
  • 4,408 posts
Posted 12 May 2020 - 12:02 PM
We will see, interested now. Can always return it anyway.
#24 Foxy_Jr
Foxy_Jr
  • 478 posts
Posted 12 May 2020 - 02:36 PM
Courtenay are doing them now.  Listed for the Tubby but I've fitted one and seems to have lasted better the the euroCP ones.
https://www.courtena...escription=true
#25 gaffer1986
gaffer1986
  • 4,408 posts
Posted 18 May 2020 - 05:02 PM
It doesn't look plastic, not sure how these clips work, not seen them before.
https://photos.app.g...3nnWFuuyH9Qsi48
#26 Foxy_Jr
Foxy_Jr
  • 478 posts
Posted 19 May 2020 - 02:57 PM
I've fitted these a couple of times and both times have failed.  Normally half way through a trackday spraying grease everywhere!
They tend to split on the peak of the concertina - the car is quite low at the back so the inner short boot seems to suffer quite badly.
So far the Courtenay one hasn't let go!
#27 gaffer1986
gaffer1986
  • 4,408 posts
Posted 19 May 2020 - 03:26 PM
Edited by gaffer1986, 19 May 2020 - 03:28 PM.
#28 gaffer1986
gaffer1986
  • 4,408 posts
Posted 19 May 2020 - 03:28 PM
Which Courtney boot did you use? I did a search under 2.2 VX220 and there website didn't have any boots.
#29 Foxy_Jr
Foxy_Jr
  • 478 posts
Posted 19 May 2020 - 05:49 PM
Link above....
#30 gaffer1986
gaffer1986
  • 4,408 posts
Posted 19 May 2020 - 06:34 PM
Ahh, sorry, didn't notice that.
#31 Krusty
Krusty
  • 527 posts
Posted 20 May 2020 - 09:32 AM
I just put a new drive shaft on, too lazy and too messy to do the boot 😂😂
but thanks for the link to the courtneys boot, just purchased one 👍👍
Edited by Krusty, 20 May 2020 - 09:34 AM.
#32 skilledCHIMP
skilledCHIMP
  • 3 posts
Posted 11 September 2020 - 09:39 AM
Hi, I’ve got my rear passage inner boot to change this weekend, am i right in thinking it’s easier just to remove the drive shaft to do this?? If i remove the drive shaft do i drain the gear box fuild?
#33 paul_mck
paul_mck
  • 284 posts
Posted 11 September 2020 - 11:13 AM
if you remove the shaft the fluid runs out
you could maybe split the shaft in situ and leave the inner end on. Bit of a faff doing the work upside down but might work.
#34 smiley
Posted 11 September 2020 - 11:33 AM
When the left side is jackup up fully, the amount of oil spillage should be minimum,
Unless you have overfilled the box way to much.
Edited by smiley, 11 September 2020 - 11:34 AM.
#35 gaffer1986
gaffer1986
  • 4,408 posts
Posted 11 September 2020 - 11:53 AM
I think it's easy to unbolt the hub carrier bolts and coil over to give you movement. Then disassemble the inner cv joint from the drive shaft. No need to disconnect the cv cup from the gearbox. Done it twice.
#36 skilledCHIMP
skilledCHIMP
  • 3 posts
Posted 15 September 2020 - 10:26 PM
Kl, will give it a go leaving the cv cup in. Thanks for the advice.
#37 gaffer1986
gaffer1986
  • 4,408 posts
Posted 16 September 2020 - 06:44 AM
Also, you need to unbolt the toe link from the upright. Once you have disconnected those three things you will have lots of movement and twist.
Unclip the cv boot straps. Slide the cv boot down the shaft then you have access to the single circlip just on the inside edge of the cv cup, pop that out with a flat head screwdriver and you can pull the cv cage and balls out. Be careful to catch the balls
The will be one other circlip on the cv cage to remove the cage from the drive shaft. Then the boot will slip off.
When reassembling use the grease to hold the balls in place, looks harder than it is as the grease actually keeps the balls in place quite well.
Last time I did mine was June so remember it quite well.
Edited by gaffer1986, 16 September 2020 - 06:45 AM.
