I have to admit your steering wheel does look good, you must have the patience of a saint.
The foam in the seat is another good mod, dunno if I have the courage to hack into my own seat...
Posted 15 October 2016 - 07:16 AM
Posted 15 October 2016 - 07:30 AM
Posted 15 October 2016 - 08:36 AM
Posted 15 October 2016 - 12:14 PM
Looks great, but be careful using foam on the undertrays parts near the exhaust can get very hot.
Thanks, this is very far from the exhaust or anything hot.
Just replaced the aux belt, hopefully it will stop slipping under full throttle in first now:
Here is a guide:
http://www.vx220.org...he-aux-belt-na/
20161015_111229 by Richard Fanders, on Flickr
Edited by gaffer1986, 15 October 2016 - 12:18 PM.
Posted 15 October 2016 - 12:17 PM
Fitting another gearbox breather as I did to my last VX220 before 07/11/16 track day at Snetterton:
Here is a guide from when I did it last time:
http://www.vx220.org...r-guide-for-na/
20161015_123700 by Richard Fanders, on Flickr
Edited by gaffer1986, 15 October 2016 - 12:29 PM.
Posted 15 October 2016 - 12:22 PM
Does anyone know which bolts holes are correct at the back of the seat?
20161015_091546 by Richard Fanders, on Flickr
The holes closest the drivers door make the top of the seat hit the head restraint, here is a photo when the top of the seat doesn't hit the head restraint because I'm using the two holes closest the centre console:
20161015_091533 by Richard Fanders, on Flickr
But when I use the two holes closest to the centre console I badly scrape along the centre console when moving the seat forwards and backwards. I didn't experience these problems in my last car:
20161015_091555 by Richard Fanders, on Flickr
Posted 16 October 2016 - 03:49 PM
Looks like you're missing the two L shaped spacers from the runners
Posted 16 October 2016 - 03:54 PM
up, and act as stops
Posted 16 October 2016 - 03:55 PM
Posted 22 October 2016 - 07:26 PM
Running really well now, ticks over smoothly and acclerates smoothly at any rpm all the way up to 7800rpm. Shift light comes on at 7500rpm but peak power is between 7400 and 7800, pretty much 215 across those 400rpm which makes gear changes flexible.
20161022_110238 by Richard Fanders, on Flickr
20161022_110229 by Richard Fanders, on Flickr
20161022_110214 by Richard Fanders, on Flickr
20161022_110203 by Richard Fanders, on Flickr
20161022_110157 by Richard Fanders, on Flickr
20161022_110146 by Richard Fanders, on Flickr
Parked up.
20161022_120851 by Richard Fanders, on Flickr
Posted 22 October 2016 - 09:37 PM
Posted 22 October 2016 - 10:34 PM
Posted 23 October 2016 - 07:22 AM
Drives really well now! 3000 miles in 3 months and my insurance is 6000 a year
Is for for your vx, and your Ferrari F40 together?
Posted 23 October 2016 - 07:36 AM
215.9 is not bad, it made 218.8 in mine many years ago, but with a different exhaust system. Sent from my SM-G920F using Tapatalk
just realised mine had stage 3 cams and the weapon R with the modified 2.5" Milltek back in April 2009 when it was mapped.
You also have 3 ft lb more torque than when it was in mine.
Which proves the 2.5" Tullet full exhaust does work well
Posted 23 October 2016 - 07:43 AM
Edited by gaffer1986, 23 October 2016 - 07:45 AM.
Posted 23 October 2016 - 07:46 AM
Obviously the weaponR was the only decent manifold available at the time
Edited by vocky, 23 October 2016 - 07:47 AM.
Posted 23 October 2016 - 07:47 AM
Smiley: What do you mean?
6000
6000 miles per year not £6000 to insure
Posted 23 October 2016 - 07:48 AM
It is a good exhaust, nice and quiet on the long drives also and doesn't overpower the sound of the ITBs when the throttle is open. I don't think I'll notice the difference between 215.9 and 218.9 because the map added around 9bhp and I'm struggling to feel it. Sounds better since the map thoughjust realised mine had stage 3 cams and the weapon R with the modified 2.5" Milltek back in April 2009 when it was mapped. You also have 3 ft lb more torque than when it was in mine. Which proves the 2.5" Tullet full exhaust does work well215.9 is not bad, it made 218.8 in mine many years ago, but with a different exhaust system. Sent from my SM-G920F using Tapatalk
