Does that mean you didn't have ITBs if you had an intake manifold. I thought ITBs just have a fixing plate that connects the ITBs to the engine?Obviously the weaponR was the only decent manifold available at the time
Things To Do. I Want This Machine To Be Mint.
#81
Posted 23 October 2016 - 07:50 AM
#82
Posted 23 October 2016 - 07:54 AM
Haha, it was just under £500 for insurance with the Trackdays and a value of £13,000. I haven't got a proof of valuation though, very hard to get one when you have mods as it's hard to value it. But I wouldn't let it go for less than £20,000 as it don't think I'll get another one and given how terribly this run when I got it I wouldn't want another one. It's close to factory smooth now.6000 6000 miles per year not £6000 to insureSmiley: What do you mean?
#83
Posted 23 October 2016 - 07:55 AM
6000
#84
Posted 23 October 2016 - 08:09 AM
weaponR was a 4-2-1 exhaust manifold and it had the webcon ITBs fitted
#85
Posted 23 October 2016 - 08:14 AM
this is from April 2009
#86
Posted 23 October 2016 - 09:25 AM
looking at the before/after graph - doesn't look like a lot has changed for the most part? A bit more at the top end and smoothing at the lower end?
nice and smooth though
20161022_110238 by Richard Fanders, on Flickr
Edited by Raptor, 23 October 2016 - 09:27 AM.
#87
Posted 23 October 2016 - 09:43 AM
It always has been good above 3000rpm. The problems where below 2000rpm and cold start which is now sorted. The graph doesn't show below 2000rpm but it was messy. I've figured out why the engine chugs when off the gas at 1250rpm.. It's because the TPS doesn't return to the set idle value if you come off the gas slowly. If I let off gas suddenly it doesn't chug. It's a pain, nothing to do with mapping but all to do with the crude TPS.looking at the before/after graph - doesn't look like a lot has changed for the most part? A bit more at the top end and smoothing at the lower end? nice and smooth though 20161022_110238 by Richard Fanders, on Flickr
#88
Posted 23 October 2016 - 09:45 AM
They're very similar to be fair, mine looks smoother though.this is from April 2009
#89
Posted 23 October 2016 - 10:24 AM
will be interesting to hear what airflow Troy reset yours to along with the tps voltage.
after having watched your revs hanging video, I think I could live with that as it is. Small problem IMHO.
#90
Posted 23 October 2016 - 03:49 PM
your new map is much better
#91
Posted 23 October 2016 - 04:19 PM
It's not a small problem when you braking and when the car gets to 1250rpm your passengers starts looking at you like you can't drive because the car is jerking about like a learner driver. I just need to remember to clutch down before 1250rpm which is hard for me as I'm lazy and normally wait until tickover.will be interesting to hear what airflow Troy reset yours to along with the tps voltage. after having watched your revs hanging video, I think I could live with that as it is. Small problem IMHO.
#92
Posted 25 October 2016 - 07:48 PM
Looking good there Gaffer. I'm changing the radiator hoses this weekend but when I'm done you'll have to come out in the supercharged vx.
#93
Posted 25 October 2016 - 08:12 PM
#94
Posted 25 October 2016 - 08:16 PM
Driving Mrs Daisy
#95
Posted 26 October 2016 - 05:57 AM
#96
Posted 30 October 2016 - 09:31 AM
Fitted RC5+ pads with shims yesterday which on first impressions are very good:
20161029_140113 by Richard Fanders, on Flickr
Greased pads and replaced and greased pins front and rear and the brakes seem very quiet for now.
This tool is very handy:
20161029_135219 by Richard Fanders, on Flickr
#97
Posted 30 October 2016 - 09:43 AM
Also too the duck taped anti rattle foam off the undertray and stuck on some proper stick foam. Doesn't rattle still so I'm pleased:
Before:
20160903_165600 by Richard Fanders, on Flickr
After:
20161029_124954 by Richard Fanders, on Flickr
20161029_124959 by Richard Fanders, on Flickr
I left most the dirt on as I hope the dirt will further help dampen any rattles.
Edited by gaffer1986, 30 October 2016 - 09:44 AM.
#98
Posted 30 October 2016 - 11:22 AM
Fitted a bulb, explains why the light wasn't working, there was no bulb in the holder, the holder was very loose so I bent it to make it fit better.
This will explain the noise in the dash during hard cornering, the old bulb must be lost in there somewhere.
20161029_151854 by Richard Fanders, on Flickr
Edited by gaffer1986, 30 October 2016 - 11:22 AM.
#99
Posted 31 October 2016 - 09:19 PM
As your car seems to be pristine now, I think you ought to come and attend to mine, I must have at least a dozen minor tidying up jobs I've been putting off for 5+ years.
#100
Posted 31 October 2016 - 09:51 PM
Haha, definitely not pristine, I need another year or two, I want to revamp the interior so it's like new and close to original and I also want to do a suspension / steering refresh when I've got a garage.As your car seems to be pristine now, I think you ought to come and attend to mine, I must have at least a dozen minor tidying up jobs I've been putting off for 5+ years.
