Looking at new discs / pads all round.
Anyone had any experience with these? Just at the top on fleabay when I typed in. Only planning road driving currently
Thanks
Posted 13 July 2016 - 07:51 AM
Thanks
Posted 13 July 2016 - 09:42 AM
Brakes are a regular topic and haven't changed too much. I suggest you search the forum for a more in debit answer, however quick summary as follows:
1. Disc type doesn't matter (unless you look at very expensive, lightweight parts). Venting/grooves make more noise and may wear pads more, gas release advantages are pad dependent.
2. Car is very sensitive to pad type. The ones in your link are just OEM quality replacements.
I suggest you look into better pads and couple them with standard discs. The link you provided is spending money in the wrong place (discs rather than pads)
Posted 13 July 2016 - 09:56 AM
do camskill still sell the M1144 and disc kits? If so, then get that for road use. and consider m1155 kit for slightly keener use and the odd bit of tracking.
Posted 13 July 2016 - 10:18 AM
this all day long
Posted 13 July 2016 - 11:37 AM
Pads: https://www.elisepar...144-brake-pads/
discs: https://www.elisepar...rd-brake-discs/
However can be had for less online; http://www.ebay.co.u...wQAAOSwSHZWfJoC (front and rear are same)
Posted 13 July 2016 - 11:57 AM
Pagid discs from Eurocarparts are anti-corrosion coated and are good quality and super cheap, especially if you can find an extra discount code!
General Discussion →
Tuning & Modifications →
The Market Place →
Cars Wanted →
Vx220 Wanted - ProjectStarted by dstarz7 , 14 Oct 2020 ![]() |
VX220 Users Gallery →
My Brilliant Yellow (Thanks For The Correction Guys!) Vx220 TurboStarted by charliedrives , 25 May 2020 ![]() |
The Market Place →
Car Parts For Sale →
Front DiscsStarted by Hammy of hamhouse , 18 May 2020 ![]() |
VX220 Discussion →
Stage 2.5 Turbo ExhaustStarted by simoambro97 , 23 Apr 2020 ![]() |
