Retrim Steering Wheel
104 replies to this topic
#1 gaffer1986
gaffer1986
  • 4,408 posts
Posted 15 July 2016 - 09:05 PM
This is the first time I've done this, but I thought I'd share me efforts in case you want to do the same. I would say this requires a lot of patience.
What's needed:
Philips screw driver
Over or heat gun
Metal prying tool to remove old leather
Stitch picker
Gorilla glue
Sand paper - and needle files will help
Quality tailor scissors
Stanley knife
Dremel type tool with sander wheel
Aliphatic Resin
Awl
Blunt needle with 0.6 - 0.8mm thick thread in your desired colour
Patience
Take the plastic cowl thing off the back
Posted Image20160614_175614 by Richard Fanders, on Flickr
Remove stitches with a stitch picker
Posted Image20160606_163406 by Richard Fanders, on Flickr
Put the steering wheel in the oven at 70 degrees Celsius several times until all the leather has been removed
Posted Image20160614_164419 by Richard Fanders, on Flickr
But the way, I've never cleaned this oven  :mellow:
Prise the leather off the steering wheel with a prying tool
Posted Image20160606_164420 by Richard Fanders, on Flickr
Posted Image20160606_165018 by Richard Fanders, on Flickr
Posted Image20160606_165600 by Richard Fanders, on Flickr
Posted Image20160614_115601 by Richard Fanders, on Flickr
Until all leather is removed
Posted Image20160614_175710 by Richard Fanders, on Flickr
Edited by gaffer1986, 15 July 2016 - 09:22 PM.
#2 gaffer1986
gaffer1986
  • 4,408 posts
Posted 15 July 2016 - 09:10 PM
After doing this you are likely to have damaged the foam, if you haven't, well done this saves you a job.
As you can see the damage that needs repairing
Posted Image20160614_175651 by Richard Fanders, on Flickr
Posted Image20160614_175642 by Richard Fanders, on Flickr
Posted Image20160614_175632 by Richard Fanders, on Flickr
To fix this you need the gorilla glue and a bit of water. The gorilla glue is easily applied with a toothpick and a small quirt of water will activate it. Fill in all the holes.
Posted Image20160614_213753 by Richard Fanders, on Flickr
Posted Image20160614_213828 by Richard Fanders, on Flickr
Posted Image20160614_213717 by Richard Fanders, on Flickr
Posted Image20160614_214209 by Richard Fanders, on Flickr
#3 gaffer1986
gaffer1986
  • 4,408 posts
Posted 15 July 2016 - 09:13 PM
Fill in all the wholes and sand the wheel to a smooth finish. Using a round and square needle file can help smooth out the finish.
Here was mine after being filled and smoothed
Posted Image20160712_151609 by Richard Fanders, on Flickr
#4 'Buchos'
'Buchos'
  • 792 posts
Posted 15 July 2016 - 09:16 PM
Always wondered how to do this.....carry on :)
#5 Wolfstone
Wolfstone
  • 12,985 posts
I think it looked better with the leather on. :lol:
#6 gaffer1986
gaffer1986
  • 4,408 posts
Posted 15 July 2016 - 09:21 PM
Separate all the leather pieces and leave under weight to flatten them out
Posted Image20160713_205811 by Richard Fanders, on Flickr
Put them on your material ready for cutting
Posted Image20160703_150336 by Richard Fanders, on Flickr
Draw around the leather, check twice that it's correct, then Stanley knife around the leather to act as a guide for your scissors then cut
Posted Image20160713_211924 by Richard Fanders, on Flickr
Then use a dremel like tool with a sanding wheel to skive (thin) the leather to match the original leather removed from the wheel, this is just around the edges of the leather for the back of the wheel where the leather overlaps to prevent a ridge.
Posted Image20160714_213959 by Richard Fanders, on Flickr
Posted Image20160715_150843 by Richard Fanders, on Flickr
Posted Image20160715_150901 by Richard Fanders, on Flickr
Edited by gaffer1986, 15 July 2016 - 09:25 PM.
#7 gaffer1986
gaffer1986
  • 4,408 posts
Posted 15 July 2016 - 09:24 PM
This is the part that needs skiving so the leather can overlap
#8 fiveoclock
fiveoclock
  • 9,453 posts
Posted 15 July 2016 - 09:25 PM
If you get that Gorilla glue on the carpet your life wont be worth living :D
#9 gaffer1986
gaffer1986
  • 4,408 posts
Posted 15 July 2016 - 09:30 PM
haha, I live alone so no one else to moan  :D Just used the dog training mats, spot the pug:
Posted Image2016-07-15_10-30-06 by Richard Fanders, on Flickr
#10 gaffer1986
gaffer1986
  • 4,408 posts
Posted 15 July 2016 - 09:37 PM
Now for the really tricky time consuming bit, use [color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]Aliphatic Resin (aka yellow glue which is very similar to PVA) to glue the section to the steering wheel. Try glue a small bit at a time as this makes it much easier and avoids wrinkles.[/color]
Posted Image20160715_210947 by Richard Fanders, on Flickr
Skived part
Posted Image20160715_211001 by Richard Fanders, on Flickr
Old against new
Posted Image2016-07-15_09-40-20 by Richard Fanders, on Flickr
As you can see I cut the leather slightly long at the top and bottom, that way I can cut it later with a Stanley knife and fold it into the groves.
Bed time now, next will be the final part, stitching.
#11 CocoPops
CocoPops
  • 17,181 posts
Posted 15 July 2016 - 09:41 PM
Fab thread! Really good how to. Not sure many would DIY it though? I'd probably glue my fingers together :lol:
#12 gaffer1986
gaffer1986
  • 4,408 posts
Posted 15 July 2016 - 09:47 PM
haha, it's similar glue to the stuff you probably used at school so not like the Ever Build Mitre Fast I used last week on a bit of furniture and glued my thumb to a tissue when I went to wipe it off. Had a white tissue thumb for the rest of the day, I wonder what people thought I'd been up to  :lol:
Baby wipe is all you need with this stuff.
Edited by gaffer1986, 15 July 2016 - 09:48 PM.
#13 Nev
Posted 16 July 2016 - 12:02 AM
I think that was fairly clear by the amount of spare time you have to do this seemingly needless and time consuming task. Was there a reason other than a bit of usage signs?
Interested to know how many hours you spend on this.
Edited by Nev, 16 July 2016 - 12:06 AM.
#14 gaffer1986
gaffer1986
  • 4,408 posts
Posted 16 July 2016 - 06:44 AM
Ouch, I'm actually a very busy person, sometimes I leave my house at 07:30 and don't get home until 21:30. I don't watch TV so I've been doing it bit by bit for the last 6 weeks in the evenings before bed, I keep going days or weeks without doing any of it. But just so happens I've had a bit of time this week because me and my girlfriend are having a rough time and I enjoy a project so I've got on with it to keep my mind off things. I wouldn't say it's needless as I've always hated shiny worn steering wheels, one of the things I love about new cars is that the interior is so fresh so I would like to see if it's possible to breath some new car into this old car.
#15 Nev
Posted 16 July 2016 - 06:55 AM
Okies, how long do you think it will take, looks like the trickiest bit will be getting new material to stretch and fit nicely to me.
If it goes wrong, you could always buy a second hand steering wheel for a few quid, I am sure there are loads about from crashed cars.
Edited by Nev, 16 July 2016 - 06:57 AM.
#16 'Buchos'
'Buchos'
  • 792 posts
Posted 16 July 2016 - 07:41 AM
Learning lots here, even a new word.... skive.... or at least the origin of that word.
#17 Frosty34
Frosty34
  • 401 posts
Posted 16 July 2016 - 07:49 AM
That is one very good tutorial
I get what your saying about the feel and look of a new steering wheel
wish i had the patiants to do it!! I covered my door cards and nearly ended up throwing them through the window......
#18 gaffer1986
gaffer1986
  • 4,408 posts
Posted 16 July 2016 - 10:08 AM
That is one very good tutorial    I get what your saying about the feel and look of a new steering wheel    wish i had the patiants to do it!! I covered my door cards and nearly ended up throwing them through the window......
Thanks, I'll keep you updated. I'm a bit unusual because I quite like doing tricky fiddly things, it helps me relax.
#19 gaffer1986
gaffer1986
  • 4,408 posts
Posted 16 July 2016 - 10:10 AM
Okies, how long do you think it will take, looks like the trickiest bit will be getting new material to stretch and fit nicely to me.   If it goes wrong, you could always buy a second hand steering wheel for a few quid, I am sure there are loads about from crashed cars.
Yeah, I'm not sure what the end result will look like, however I like what I've done so far, probably taken me 6 hours on total but it's hard to tally it up. I think once I've done it I could probably do the whole thing in two lots of 4 hours. Im ahead of you there, this is not my steering wheel, it's once I bought off myles a couple of months ago for £50.
#20 gaffer1986
gaffer1986
  • 4,408 posts
Posted 16 July 2016 - 11:31 AM
This is the glue I'm using, when gluing make sure the leather is in the right place, once you've glued it you can't re-glue very well because the leather will already be plasticised. Coat the glue using an artist brush or something similar to both the steering wheel and the leather to soften the fibers allowing them to mold into one another.
Posted Image20160716_121009 by Richard Fanders, on Flickr
Posted Image20160716_120025 by Richard Fanders, on Flickr
A toothpick is a good way of getting glue into tight areas
Posted Image20160716_120743 by Richard Fanders, on Flickr
The awl can be used to press the leather in the gap allow the glue to set
Posted Image20160716_120812 by Richard Fanders, on Flickr
