I'm sure swapping to an air cooler will help (with sufficient air flow and rad size) if the installation is easier.
As for the water rad, I'm not sure turning the heater on is a good test of what could be achieved with a decent size additional rad in the cooling system. Acidpopstar is seeing water temps of 91 on hot track days without a pre rad up front, which gives a good indication of the impact it has on the efficiency of the main rad.
I assume you've seen the Hoffman's thread where they got inventive in adding extra cooling for oil and charge coolers? http://www.hofmanns....ropa-build-blog
Haven't seen that thread, thanks for the link. Interesting build.
One solution I was thinking of before going for the pro alloy was to have one radiator in each ear for the CC, would have been interesting to see someone try that.
I had a talk with the cooling expert at work today to get some general info to continue my investigation. The oem oil cooler probably transfers about 20-25kW and the front radiator on a standard car about 80kW. In general cooling the oil does 1/3 of the engine cooling. I will get on with calculating how big an air cooler need to be to remove 25kW to get an idea of if I will remove the oem cooler or not.
One suggestion was to start with adding the air-oil cooler in parallel to start with. Adding it in series as it's usually done creates a pressure drop that affects the oil flow.
One interesting solution for adding cooling surface for both cc and engine coolant would be to get hold of finned pipes and run them front to rear and possibly adding some air flow. But probably hard to find a suitable alu-extrusion. Would be a nice stelth mod tough
