Cv Joint Boot
96 replies to this topic
#21 gaffer1986
gaffer1986
  • 4,408 posts
Posted 26 July 2016 - 03:40 PM
Try *How to* CV Inner boot replace thread in guides and tutorials.
Do it yourself... the weather's nice and anyone half decent (PSR, Essex Autosport etc)  will have a wait time.
A super easy job, allbeit messy
I may give it a go if you think it's easy, I'm worried I'd take the drive shaft out and then lose all my oil from my diff.
Even I did it and it's still fine a few years on... go on... give it a whirl....
Sheesh - what is it with you and obsessing over oil loss? :D
Haha, I'm worried about oil loss because I'm told it's normal and others say I shouldn't have any, so I want to see what people actually experience. If most use oil then it must be normal.
But then again most K series blow head gaskets but that doesn't make it right :D
#22 gaffer1986
gaffer1986
  • 4,408 posts
Posted 26 July 2016 - 03:41 PM
I raised this exact thread last month... has all the information and I managed to do it myself in about 4 hours, so a garage should do it in 2.   http://www.vx220.org...t-where-to-buy/
I was told 1.5 hours so about right.
#23 gaffer1986
gaffer1986
  • 4,408 posts
I paid £15
Where did you get yours from? I called Kia.
#24 CHILL Gone DUTCH
Posted 26 July 2016 - 03:45 PM
#25 CHILL Gone DUTCH
Posted 26 July 2016 - 03:46 PM
You will have to buy your own grease as the stuff which comes with this is not enough and to thin
Edited by CHILL Gone DUTCH, 26 July 2016 - 03:46 PM.
#26 gaffer1986
gaffer1986
  • 4,408 posts
Posted 26 July 2016 - 03:53 PM
Awesome thanks, what grease do you recommend?
#27 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 26 July 2016 - 04:07 PM
#28 gaffer1986
gaffer1986
  • 4,408 posts
Posted 26 July 2016 - 04:08 PM
Brylcreme. Got it.
#29 gaffer1986
gaffer1986
  • 4,408 posts
Posted 26 July 2016 - 05:32 PM
Mess
Posted Image2016-07-26_06-30-01 by Richard Fanders, on Flickr
Posted Image20160726_181342 by Richard Fanders, on Flickr
Although I think these toe links may be upgraded.
Posted Image20160726_181444 by Richard Fanders, on Flickr
#30 CHILL Gone DUTCH
Posted 26 July 2016 - 05:35 PM
The fuel cut off switch is direct inline with the cv boot Always gets covered
#31 gaffer1986
gaffer1986
  • 4,408 posts
Posted 26 July 2016 - 05:39 PM
I wondered what that little thing was.
#32 fiveoclock
fiveoclock
  • 9,453 posts
Posted 26 July 2016 - 06:07 PM
Buy a box of vinyl gloves. You'll need them!!
#33 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 26 July 2016 - 06:15 PM
Lol Just ordered one as I damaged mine at the national ,last time was 4 years ago ...always the same side
#34 PaulCP
PaulCP
  • 6,066 posts
Posted 26 July 2016 - 06:31 PM
Probably not helped by the low ride setting you have
#35 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 26 July 2016 - 06:33 PM
Nope the car isn't low ....just spitting some nice clean thick grease 😊😊😊
#36 gaffer1986
gaffer1986
  • 4,408 posts
Posted 26 July 2016 - 08:10 PM
I don't think I'm going to attempt this. Looks like the kind of job that would be easy with a lift and very hard laying on the floor.
#37 smiley
Posted 26 July 2016 - 08:38 PM
You can hcoose between a kia sedona cv: 0 K55 22 2540
Or a volkswagen: 1KO 498203
Inner cv needs 150 grams of grease.
Outer cv needs 130 grams of grease.
If you track the car, it is advised to add a breather, so hot air can escape.
If you want top of the line grease, get something like Redline CV-2 (up to 260 degrees, about 30 eur a jar)
If you want the ferrari of greases, get NEO HPCC1 (up to 649 degrees, about 170 euro a jar)
Edited by smiley, 26 July 2016 - 09:05 PM.
#38 gaffer1986
gaffer1986
  • 4,408 posts
Posted 26 July 2016 - 08:57 PM
That's good information, the guide says you need to remove the wishbone ball joints to do the work but later someone else says you can get away with removing only the toe link. Don't really want to go removing the ball joints. To be honest I don't understand most of it as I don't know what's some of stuff means so I may get a garage.
#39 smiley
Posted 26 July 2016 - 09:01 PM
You will also not like the breaker bar routine for the central wheel nut.
Just take it to a garage indeed.
(don't forget to tell them to jack it up as high as possible, to minimise oil from gearbox spil)
If you have a gearbox breather tube, tell them they can also use that to fill her back up. (slow though)
Edited by smiley, 26 July 2016 - 09:02 PM.
#40 slindborg
Posted 26 July 2016 - 09:05 PM
Again, there is no fcuking oil to spill if you don't pull the inner joint from the box, just pop the clip out and it all slides out.
