Handbrake Binding?
handbrake
6 replies to this topic
#1 james4563
james4563
  • 268 posts
Posted 28 July 2016 - 01:53 PM
When parking up and reversing a slow speed I can hear a slight squeal as though the brakes are slightly applied. It's normally just when going in reverse, if I was say backing out of a parking space or driveway.
Is this normal or does it suggest that maybe the handbrake is binding?
My handbrake does only come up like 2 or 3 clicks, won't move more than that really.
I'm used to a Celia that used to do about 10 clicks before the handbrake would bite, so not sure if this is normal for the VXT or not  :D.
#2 siztenboots
Posted 28 July 2016 - 02:39 PM
brake pads do tend to move about a bit , could be a lip on the disc
#3 Stevie Dubyah
Stevie Dubyah
  • 1,534 posts
  • Interests:Invasive Operations
Posted 28 July 2016 - 02:51 PM
10 clicks before biting on your old car? :o
Didn't that leave a mark on your headlining?
#4 james4563
james4563
  • 268 posts
Posted 28 July 2016 - 03:42 PM
I might have exagerated a bit.
Lets put it this way, on a flat I think it was 6/7 clicks. If I was stopping on an incline I had to give it and extra click ( sometimes using 2 hands ) so that I wouldn't roll :D
If I parked on a hill and put that Celica handbrake on 3 clicks, soon as I took my foot off the brake pedal I'd be sliding away back down the hill! ( It did use handbrake shoes mind, rather than calipers ).
Is 3 clicks normal for the VX then? I had a look at the adjustment procedure earlier as per this document. I guess I could just check if the measurement is correct with the handbrake released, 76mm.
Important: For the auto adjustment system tofunction correctly, it is essential that eachcaliper lever fully returns when the parkingbrake lever is fully released. Check thatdimension X (illustrated) is minimum of 76 mm,to ensure that caliper levers are fully returned.
#5 Stevie Dubyah
Stevie Dubyah
  • 1,534 posts
Posted 28 July 2016 - 03:49 PM
3 is about right. I refurbished my rear calipers and changed the handbrake cable and took a wee while to self adjust, but it's about 3 clicks now.
What do MOT rules stipulate?
#6 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 29 July 2016 - 02:31 PM
That if its fitted it has to work.. that's about it
#7 siztenboots
Posted 29 July 2016 - 02:36 PM
as long as the centre pull cable is not snagged on the undertray, a bit of LM grease would be good and check the pull cable sits central.
Also tagged with one or more of these keywords: handbrake
