Hi
I have some problems with the boost in my car.
When i accelerate from low revs i get good boost (about 1,3 bar). But when the revs came up to about 3500 rpm the boost drops down to about 0,5 bar.
I have the K04 turbo, charge cooler, 3" exhaust, Open air filter. I only know that it´s a stage 3 map, i don't know the fabricate.
I have tried to find the problem but now i run out of ideas.
The following is checked.
I have made a pressure test of the boost system and there is no leaks from the air filter to the inlet into the engine.
I checked the thin vacuum hoses, and they were good.
I have change the blow off valve to a forge.
I have change the both solenoids (boost and vacuum).
I have disconnect the hose to the wastegate "controller" and accelerate the car, now there should be very much boost.
But there are no different. I also tried to force the wastegate to be closed with a thick metal thread, no different.
I have tried with the original intercooler to see that the chargecooler was ok. Same problem with both.
I have disconnect the exhaust to check that the catalysator was not burned, it was ok with good flow (no blocks).
I have changed the hose between the AFM and the turbo inlet to a metal tube, because i heard that the hose could collapse.
I have dismounted the turbo to check for cracks or if there was to much play on the turbine, i think it looks good.
Does anybody have a tips for me where to search for the failure?
best regards Fredrik
