Roof Cable Just Snapped. Help Please!
22 replies to this topic
#1 muckyman
muckyman
  • 340 posts
  • Interests:Barmaids
Posted 07 September 2016 - 05:16 PM
Hi all, putting my sold top on and one of the cables just snapped right at the end (pic below).
Any suggestions on a fix? I can't even work out how it attaches onto the rigid end bar - does it need drilled out?
Please help as soon as poss, it'll rain soon and my VX lives outdoors :-(
http://i949.photobuc...BE0F886BBB1.jpg
#2 jim61
jim61
  • 384 posts
Posted 07 September 2016 - 05:33 PM
You need a new cable - it's crimped and not fixable ( I have had to try as a quick fix -unsuccessfully ) Best to fit the new improved version × 2 available from EBlay or someone on the forum ( search?)
#3 muckyman
muckyman
  • 340 posts
Posted 07 September 2016 - 05:36 PM
Do you know how the end fixes to the swivel point? Does it need drilled out or does the bar need disassembled and unbolted from the inside of it?
#4 muckyman
muckyman
  • 340 posts
Posted 07 September 2016 - 05:40 PM
Just found the guide to do this, just got ta source a cable now. Anyone got any links or recommendations?
#5 jim61
jim61
  • 384 posts
Posted 07 September 2016 - 05:43 PM
Very small countersunk socket head screw , bit tricky to change but the new cables are looped so don't get bent double and damaged in the process, if you only change one do the front ' cos if that goes as mine did its roof off or 25 mph😠,have a guess what the weather was like when this happened. PS electricians access rods ( mine anyway) have the same thread and make the fitting way easier 👍
#6 jim61
jim61
  • 384 posts
Posted 07 September 2016 - 05:49 PM
Elizp987 ?
#7 WrightStuff
WrightStuff
    i am sheldon cooper
  • 2,238 posts
Posted 07 September 2016 - 05:54 PM
Yes, Liz sells them.
http://www.ebay.co.u...wCAcnn6w5MSLyAg
Different design so should not snap in the same place as the OE one.
You should just be able to join your current broken end to the new cable and then pull it through, though this method didn't work for me as the seam was too tight. I had to use a straightened metal coat hanger to drag the new cable through.
#8 muckyman
muckyman
  • 340 posts
Posted 07 September 2016 - 05:55 PM
Elizp987 ?
Just sent her a PM, so hopefully she'll see it and reply soon. Otherwise it'll have to be an eBay one tomorrow...
#9 muckyman
muckyman
  • 340 posts
Posted 07 September 2016 - 05:57 PM
  Yes, Liz sells them. http://www.ebay.co.u...wCAcnn6w5MSLyAg Different design so should not snap in the same place as the OE one.   You should just be able to join your current broken end to the new cable and then pull it through, though this method didn't work for me as the seam was too tight. I had to use a straightened metal coat hanger to drag the new cable through.
Oh, that's one of hers? I was looking at that on eBay just now. I'll get it ordered now. Ta all
#10 james.a
james.a
    Proud member of the Northants Pedantic Crew
  • 2,033 posts
  • Interests:Driving Trigger's broom since March 2010
Posted 07 September 2016 - 07:07 PM
Where are you bas d can you borrow a roof locally?
#11 muckyman
muckyman
  • 340 posts
Posted 07 September 2016 - 07:11 PM
St Albans...
#12 james.a
james.a
  • 2,033 posts
Posted 07 September 2016 - 07:17 PM
Ok. Any folks locally who can lend? Redeem .org after recent squabbles? I'm in Northampton so probably a little far out the area, otherwise you'd be welcome to borrow one of mine.
#13 muckyman
muckyman
  • 340 posts
Posted 07 September 2016 - 07:34 PM
Cheers James. I may actually be Ok. Looking at the forecast it seems fine until Saturday. With luck, the one I ordered will arrive Friday and I can fit it Friday evening. Fingers crossed.
#14 Barton
Barton
    Barton
  • 1,022 posts
  • Interests:Lead NPC spanner man
Posted 07 September 2016 - 07:52 PM
I could meet half way and lend you a roof or cable poss tomoz or fri
#15 Barton
Barton
    Barton
  • 1,022 posts
Posted 07 September 2016 - 07:53 PM
Or a cover
#16 P11 COV
P11 COV
  • 7,683 posts
Posted 07 September 2016 - 07:55 PM
The wife fixes mine :)
#17 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 07 September 2016 - 09:04 PM
You have a PM 😀
#18 muckyman
muckyman
  • 340 posts
Posted 07 September 2016 - 09:24 PM
Replied 👍🏻
#19 Harry Hornet
Harry Hornet
  • 4,973 posts
Posted 07 September 2016 - 09:37 PM
I have a spare cable..N Herts Go through Hatfield and North Orbital every day day Phone me tomorrow to link up 07885 243888 Hh
#20 muckyman
muckyman
  • 340 posts
Posted 07 September 2016 - 09:58 PM
Ta Mr Hornet, but I think I'm sorted now. Got a new cable ordered and a loan of a roof in the meantime. Many thanks to yourself and all that offered help - great forum spirit
