Hid Fog Lamp Mod > Switches & Wiring Advice Req.
Posted 18 September 2016 - 11:06 PM
Posted 19 September 2016 - 06:38 AM
Great, you've fitted HIDs into a lamp not designed for them and now you want to have them on all the time? No thanks. I'd rather not be blinded.
[font="arial, sans-serif;font-size:16px;"]You must use headlights when visibility is seriously reduced, generally when you cannot see for more than 100 metres (328 feet). You may also use front or rear [/font]fog lights[font="arial, sans-serif;font-size:16px;"] but you MUST switch them off when visibility improves.[/font]
Posted 19 September 2016 - 09:20 AM
Posted 19 September 2016 - 09:27 AM
I completely disagree with you and so does the law.
Posted 19 September 2016 - 12:29 PM
Why not use them as extra high beams ?
Posted 19 September 2016 - 01:04 PM
the fogs are better used as holes to get air to the brakes
Anyway, the wiring diagrams in the "dubious legality" copy of the TIS you share will tell you the wires you need to fiddle with.
Posted 19 September 2016 - 10:15 PM
Posted 19 September 2016 - 11:29 PM
Ironically I can't even read the dubious TIS file, it's PC only and I'm mac!the fogs are better used as holes to get air to the brakes
Posted 20 September 2016 - 10:59 PM
Also tagged with one or more of these keywords: hid, fog lamps, switches, wiring
General Discussion →
Tuning & Modifications →
Ecu Fault ?Started by Egor , 15 Feb 2018 ![]() |
VX220 Discussion →
Which Bulb And Which Hid Conversion KitStarted by MJ101 , 31 Oct 2015 ![]() |
VX220 Discussion →
Indicator FailureStarted by Bandris11 , 24 Sep 2014 ![]() |
14V Hardwire For In Car CctvStarted by Benzola , 06 Mar 2013 ![]() |
Fan Switch Wiring...Started by Dunk , 03 Feb 2013 ![]() |
