Inner Cv Joint
27 replies to this topic
#21 BRG_Rob
BRG_Rob
  • 19 posts
Posted 10 June 2024 - 02:19 AM
For any one this may help:
https://www.autodoc.co.uk/snr/15823150
Short shaft, NTN/SNR. I'll confirm in a week or so whether its correct or not. According the the part number searches I've done it is.
#22 stevieturbo
stevieturbo
  • 89 posts
Posted 12 June 2024 - 04:48 PM
correct for full shaft, or just the inner CV ?
Are turbo and n/a same ?
#23 BRG_Rob
BRG_Rob
  • 19 posts
Posted 13 June 2024 - 02:26 AM
For the link I added above?
Seems to be correct for full shaft. I believe turbo and 2.2 are the same, same gearbox (albeit with different ratios), hubs and shafts.
Shaft has been shipped, I should have it in a few days to confirm. If they actually send a NTN/SNR shaft then it should be the same as OEM which is £200 +vat from Elise Parts. Naturally I might have ordered completely the wrong part in which case I'll be paying that 200+vat  :lol:
Inner CV joint looks to be from an Astra GSI, they are available(ish) but it ends up being £80-100 more for a shaft than a branded joint and a load of mess so I didn't really see the point.
#24 stevieturbo
stevieturbo
  • 89 posts
Posted 13 June 2024 - 04:39 PM
So short shaft is same as Astra ?
Is long shaft also just from an Astra ?
Or are some aspects unique to the 220 ?
Just for reference for the future.
#25 BRG_Rob
BRG_Rob
  • 19 posts
Posted 16 June 2024 - 07:37 PM
Right now I'm really not sure.
The shaft I have bought is for a VX220 according to the part numbers. The inner joint on the short side seems to be from an Astra GSI - I don't know about the long shaft or inner joint.
The long shaft from what I can tell is different to most of the Vauxhall range as it doesn't use a centre support bearing, there is a thread on here somewhere showing someone 'upgrade' to equal length shafts which on a FWD makes a for a big difference, on a RWD I am not convinced.
#26 blackoctagon
blackoctagon
  • 192 posts
Posted 16 June 2024 - 08:33 PM
Mildly related, but I have a centre support bracket from a US car that uses the equal length shafts (I think it's a Saturn Ion Redline - but don't quote me) as they used the Z22se as the L61 engine and it bolts on to the block and girdle
The Redline used the LSJ - the 2.0 version, aka SAAB B270, but supercharged rather than turbo. Other variants use the 2.2.
If i had the actual centre shaft I may have made the effort to go for equal length driveshafts, but I also realised it narrowed my options for my 4-2-1 exhaust in terms of space, so I gave up.
[edit] Now that I write that all out an old SAAB would probably give up most of the bits to anyone doing a conversion.
Edited by blackoctagon, 16 June 2024 - 08:36 PM.
#27 BRG_Rob
BRG_Rob
  • 19 posts
Posted 28 June 2024 - 11:22 AM
Yes I think there is someone on here who has done the conversion.
My shaft arrived and looks 100% correct - yet to fit it as I've got the exhaust manifold off to repair a crack, driveshaft it next!
#28 stevieturbo
stevieturbo
  • 89 posts
Posted 04 December 2024 - 08:13 PM
Ever get it fitted ?
