Edited by Matthew Bentley Racing Ltd, 13 December 2016 - 10:24 PM.
Nitron Street Series Group Buy - Until 20Th Nov 2016
#61
Posted 13 December 2016 - 10:23 PM
#62
Posted 14 December 2016 - 06:14 PM
#63
Posted 15 December 2016 - 07:37 AM
I thought that too (I got sent turbo dampers for my NA) but it seems to have always been the case: http://www.vx220.org...s-spring-rates/So nitron go to the trouble of having turbo or n/a shocks seperate on their website but there is no difference between the two once there is a cock up with the orders, funny that.
#64
Posted 16 December 2016 - 09:39 AM
#65
Posted 04 January 2017 - 01:48 PM
I had a cold evening on the floor of the garage last night fitting & tweaking these, the rears are very straight forward - took about 15 minutes a side to swap, the fronts require the mounts to be changed which is a little more tricky - the front passenger side was reasonably accessible, didn't need to take the arch liner out to do it, the drivers side was a bit of a pain - the ABS pump sits on the top of the mount & the bolts on mine we're predictably a bit rusted, small & hard to get at - need to get a spanner in the small space on top of the mount but under the pump to hold the other end of the bolt, likewise the back of the two bolts holding the mount on were awkward to get at - the top one especially, I had to remove the arch liner on the drivers side.
I have one of these: http://www.makitauk....driver-lxt.html which was very useful for getting some of the bolts in & out, not masses of torque, but for getting the new bolts in & 90% done it was a good time saver.
However, what a difference! The car doesn't crash about anymore - not wallowy at all & still stiff in the corners, but handles Hampshire's lumpy roads far better. Obviously if I had the originals refurbished it would make a difference, but I'm very happy with the result, as an aside it looks like mine has had some work in the past, one shock had had the original flaky collar replaced with a metal one, the rest originals.
#66
Posted 04 January 2017 - 03:01 PM
Just to add to the above. I struggled to undo the nuts on the bottom of the abs rubber bushes. (nut would turn but wasn't coming off - bolt wasn't moving)
Solution was use a pair of mole grips to hold the rubber and what ever mount it contains and this enabled me to get the nuts off.
Hope this helps!
#67
Posted 09 January 2017 - 01:12 PM
Where there any left over to buy for a NA?
Edited by Stocky, 09 January 2017 - 01:13 PM.
Also tagged with one or more of these keywords: nitron, group buy, street series, mbr, matthew bentley racing, suspension
The Market Place →
Car Parts For Sale →
Oem Bilstein SuspensionStarted by Ni S , 02 May 2020 ![]() |
The Market Place →
Group Buy Room →
Nitron Damper Group BuyStarted by Matthew Bentley Racing Ltd , 24 Apr 2018 ![]() |
General Discussion →
VX220 Discussion →
Nitron Ntr Advice. Na / Turbo Swap - Suspension.Started by dstarz7 , 26 Feb 2018 ![]() |
The Market Place →
Quantum Shocks ,Started by turboluca , 09 Dec 2017 ![]() |
The Market Place →
Group Buy Room →
Bilstein Oe Dampers Group BuyStarted by Matthew Bentley Racing Ltd , 04 Dec 2017 ![]() |
