Ufods Harrop Speedy
103 replies to this topic
#1 ufods
ufods
  • 235 posts
Posted 04 January 2017 - 07:32 AM
Hey.
I am Christian from Germany and this is my Speedster.
Attached File  img_4014 neu.jpg   97.23KB   24 downloads
currently mods
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]B207r with oem internals, TTV lightened flywheel and balancer delete, external trigger, Sachs organic clutch, 3" full Tullet, Siemens 630 injektors, Dbilas valve springs, ZZP Stage 1 cams, Dutch ECU software and [/color][color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]Harrop charger[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]Öhlins suspension and 15' ATS DTC with Toyo r888[/color]
Still to come this winter:
Hispec belled discs
AP2 to the rear
Water injection
#2 ufods
ufods
  • 235 posts
Posted 04 January 2017 - 07:48 AM
#3 ufods
ufods
  • 235 posts
Posted 04 January 2017 - 07:49 AM
#4 vocky
Posted 04 January 2017 - 08:18 AM
if you seek more power I would advise you get some zzp stage 3 cams thumbsup
#5 Tonie Pettersson
Tonie Pettersson
  • 423 posts
Posted 04 January 2017 - 08:22 AM
Great looking car. Really like the 15" rims.
#6 siztenboots
  • 26,613 posts
Posted 04 January 2017 - 08:48 AM
Nice wheels, how much calipers clearance, must be close?
#7 ufods
ufods
  • 235 posts
Posted 04 January 2017 - 08:53 AM
Today i get arround 305 HP with 80mm / 3.15 Pulley. I will post a OBD Power run later. When i decide for cams i go for stage 1 because i do not want the power in the high rpm range. But i am not sure now, of this was the right decision. But i am power limited because of the stock engine and my max power aim will be 340 HP. Which hopefully will be no problem with WI and smaller pulley
#8 ufods
ufods
  • 235 posts
Posted 04 January 2017 - 08:58 AM
And also nice to drive. I do not see any downsides. Maybe a good driver on a fast track - i am not. I do not have any grip problems: when the car is straight, there is no slip in 2. gear. Save unsprung weight and comfort is great.
#9 SteveA
SteveA
  • 9,152 posts
Wheels look great thumbsup
#10 ufods
ufods
  • 235 posts
Posted 04 January 2017 - 09:00 AM
I am even on 308mm disc in the front 😃
#11 CHILL Gone DUTCH
Posted 04 January 2017 - 09:44 AM
excellent work, car looks great, keep us up to date with your project,
SC projects are a bit thin on the ground this year
#12 Exmantaa
Posted 04 January 2017 - 09:58 AM
Keep the 80mm pulley and start tuning your ignition settings for more power. If you still have a stock head, this will be a restriction for higher power and Stage 2 / 3 cams will not bring much extra.
A B207 + Harrop loves to rev and we're getting around 355/360 with an 80mm pulley @7.8K. Problem is to keep that power at higher (track) temps, but that's where we need the WI for. :happy:
#13 CHILL Gone DUTCH
Posted 04 January 2017 - 10:06 AM
:yeahthat:
#14 CHILL Gone DUTCH
Posted 04 January 2017 - 12:10 PM
Has anyone tried the stage three ams yet vocky ?? that you no off
#15 vocky
Posted 04 January 2017 - 04:15 PM
most had stage 2 zzp cams, but after the 550 bhp Harrop engine my suspicions were proved right, that the mild cams are the cause of the sub 400 bhp power limit and not the inlet manifold.
That engine had stage 3 NA cams, not the milder zzp stage 3 cams.
Edited by vocky, 04 January 2017 - 04:16 PM.
#16 CHILL Gone DUTCH
Posted 04 January 2017 - 04:19 PM
  most had stage 2 zzp cams, but after the 550 bhp Harrop engine my suspicions were proved right, that the mild cams are the cause of the sub 400 bhp power limit and not the inlet manifold.   That engine had stage 3 NA cams, not the milder zzp stage 3 cams.
Which leads nicely on to mynext question, How much can I safely push my Saab b207 2.2 without risking things ???
#17 ufods
ufods
  • 235 posts
Posted 04 January 2017 - 04:36 PM
Ignition is fully optimised. I know that i have not the best power. I have knocking beginning at 5900 und most 6400 rpm and habe to pull back ignition masiv. The reason for that i do not know. I hope WI will help. I know that harrop loves to rev - my limiter is 7200, i shift @ 7000. i am afraid of high revs for the oem saab.
#18 CHILL Gone DUTCH
Posted 04 January 2017 - 05:05 PM
Maybe you have read this before, but i found i was getting knock from a ignition setting when the ignition is to low, im not saying this is the case for your self but can you rather post or pm me your ignition setting or even email me one of your files as i collect obdtuner maps for fun
#19 ufods
ufods
  • 235 posts
Posted 04 January 2017 - 05:08 PM
...yes, i read that from you. I will send you some stuff 😃
#20 CHILL Gone DUTCH
Posted 04 January 2017 - 06:17 PM
That would be great thanks pm sent
