Ufods Harrop Speedy
#21
Posted 04 January 2017 - 08:44 PM
#22
Posted 04 January 2017 - 09:46 PM
Details of the wheel fitment and supplier please, 15" not available here any more
#23
Posted 04 January 2017 - 10:48 PM
#24
Posted 05 January 2017 - 08:05 AM
#26
Posted 05 January 2017 - 03:08 PM
Are they from Regelin?Steel Pistons for AP2
#27
Posted 05 January 2017 - 04:00 PM
#29
Posted 07 January 2017 - 02:52 PM
this is the end in 2016. I know there are some 20-30 Ponies left. But as there is no headwork and only stage 1 cams - maybe thats the explanation.
#30
Posted 07 January 2017 - 03:59 PM
B207r with oem internals, TTV lightened flywheel and balancer delete, external trigger, Sachs organic clutch, 3" full Tullet, Siemens 630 injektors, Dbilas valve springs, ZZP Stage 1 cams, Dutch ECU software and Harrop charger
That looks a bit low for your specs, but at least you do not have the typical dip around 6.8K rpm...
(is your weight correct? 950kg seems a bit low for a Harrop Speedster + driver +fuel...)
With your cams, valve springs and injectors you could safely run that to 8K. We have the limiter now set @ 7.8Krpm with the same DBilas springs.
Can you post the OBD file of that run? Curious to your ignition settings.
#31
Posted 07 January 2017 - 06:20 PM
#32
Posted 07 January 2017 - 07:17 PM
Due to the shorter crank throw, your piston speed is a lot lower than a Z22SE engine. Your B207 running @7700rpm will have the same mean piston speed as a 2.2 engine running 7000 rpm. And a lot of SC-2.2's run that all day long.
#33
Posted 07 January 2017 - 07:41 PM
#34
Posted 07 January 2017 - 08:04 PM
#35
im not sure what your personal weight is Christian but i edited the power run and put 1000kg to match what i put in mine and the power is only 323pk
#36
Posted 07 January 2017 - 08:11 PM
#37
Posted 07 January 2017 - 08:12 PM
#38
Posted 07 January 2017 - 11:31 PM
Alos look into a flowed head, as that will be a major restriction for your max power.
#39
Posted 08 January 2017 - 12:17 AM
Headwork will be fine. Will see what Wi makes to the HP. We should not forget the weak Saab OEM Pistons.
