In fact you are right, this is at 1mm lift.
.050 might be the references used by compcams
http://www.crateengi...om/PDFS/ECS.pdf
Posted 11 January 2017 - 11:10 PM
Posted 19 January 2017 - 12:06 PM
Love it.
Really interested to see how you are getting the 308mm disks under 15" wheels?
I'm looking at putting 15x8.25 wheels with an offset of et20 on mine, with standard caliper, currently have 308mm and spaced caliper but thought I would have to reduce the disk back to standard of 288mm?
Many thanks
Dan
Posted 19 January 2017 - 11:12 PM
Posted 20 January 2017 - 11:37 PM
Posted 21 January 2017 - 12:22 PM
Thank you!
Have spoken to them so just need payday before ordering.
Dan
Posted 21 January 2017 - 08:38 PM
That sounds good. It is a huge benefit to go for 15'Thank you! Have spoken to them so just need payday before ordering. Dan
Posted 26 January 2017 - 10:05 AM
2 piece discs are on the car car and fit under the rims.
i use eliseparts 10mm spacer instead of the normal 11,0 / 11,5mm spacer fur the 308 disc upgrade. because of that i hat to remove some material from the ap2 caliper - but that is no problem in the outside area. i want to fit the pad perfect on the disc.
Posted 26 January 2017 - 05:58 PM
nice snug fit there
Posted 27 January 2017 - 06:55 AM
Quick remark about the EP spacers.
I bought 308mm discs, spacers (said to fit the 308 discs) and bolts last year from them. Was EXTREMELY anoyed when I found they didn't fit. How can they sell something that so obviously doesn't fit ???
The choice was between machining some material like you did or get an extra 1,2 - 2mm shim in place. I went with the extra shim.
Posted 27 January 2017 - 07:34 AM
bad story
try the seriously lotus spacer which are 11,5mm if you want to find a better solution.
I choose the thickness of the spacer regarding the fitment of the brakepad on the disc.
I did not use the 11,5mm spacer because the pad was a little bit outeside the disc
Posted 27 January 2017 - 01:32 PM
Thanks for the update!
Looks brilliant and im sure performs great too!
Dan
Posted 04 February 2017 - 05:06 PM
nice snug fit there
Not so nice.
Never go in the gravel on a track ,
Posted 06 February 2017 - 05:24 PM
you can fit the water injection pump in there now
Posted 06 February 2017 - 05:35 PM
Posted 18 February 2017 - 08:11 PM
