Knocking Noise (Yep, Another)
any ideas
30 replies to this topic
#1 MartinS
MartinS
  • 5,173 posts
  • Interests:Track days
    Pubs
    Sausages
Posted 05 January 2017 - 12:27 PM
Laurens car has had a weird solid sounding knocking coming from the front of her car for a while now.
The cars been looked at by a couple of experts in the past and have been unable to track it down but now it seems very obviously coming from the front middle area.
If you rock the car it carries on for just a bit after you've stopped like its something swinging possibly.
Any ideas as to what could do that in that area, maybe around the steering rack?
Martin S
#2 sford
sford
  • 1,454 posts
Posted 05 January 2017 - 12:51 PM
Could it be the alarm or horn sounder swinging around loose somehow? Trying to think of things in the front that may cause this. You may find it hard to trace as the knock will reverberate along the panels in that area.
#3 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 05 January 2017 - 12:59 PM
I was thinking about those. I agree its a sod to get in there as it sounds right deep inside the crash box area.
#4 chris_uk
Posted 05 January 2017 - 01:10 PM
is it the pads in the calipers moving?
Edit: ignore me, i cant read properly.
Could it be a bolt or something rolling about?
Edited by chris_uk, 05 January 2017 - 01:12 PM.
#5 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 05 January 2017 - 01:13 PM
could be the washer bottle... with the liquid moving it would explain why it keeps happening after you stop moving the car
#6 techieboy
Posted 05 January 2017 - 01:18 PM
Knackered shock? Knackered ARB drop link(s)? Knackered tie rods on the steering rack knocking?
#7 Pidgeon
Pidgeon
  • 5,254 posts
Posted 05 January 2017 - 01:26 PM
Does it have an uprated ARB?  My one incher knocked badly
#8 Andy_VX
Andy_VX
  • 2,050 posts
  • Interests:Cars, Boats, F1, Cycling, Home Cinema, Music.
Posted 05 January 2017 - 01:58 PM
Bit odd that it's coming from the middle, I would have said ARB drop links, mine knocked when they were knackered. Easy to check for wear.
#9 chris_uk
Posted 05 January 2017 - 02:19 PM
Can you get zoobeef back down? He will be able to find it.
#10 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 05 January 2017 - 03:13 PM
Thanks Matt, that video is the noise exactly. So what part is knackered there, tie rods 'on' the steering rack? Any diagram welcome.
Martin
ps Zoobeef and Bot tried finding it. I just had delivered new drop links and ball joints but when I went to start the job it just seemed really clear now that  it wasn't them, as the noise has got worse since they looked at it. It echos thorugh the car so has been a pig to track. No notable feel when driving and its been like it at least for a year.
Edited by MartinS, 05 January 2017 - 03:15 PM.
#11 chris_uk
Posted 05 January 2017 - 03:25 PM
Just swap the steering rack out for a new refurbed one from titan :)
#12 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 05 January 2017 - 03:32 PM
Can you not just replace parts?
How much is a refurbished steering rack?
Martin
#13 chris_uk
Posted 05 January 2017 - 03:50 PM
Easier to just replace the rack. Geo will have to be done again mind.
#14 turbo boy
turbo boy
  • 1,161 posts
  • Interests:Cars, fitness, fishing, sports
Posted 05 January 2017 - 03:57 PM
Could be the front ball joints. I had exactly the same kind of thing and they were the culprit... Very similar to the worn rack noise too... which worries me since I had already replaced it. Can you feel a clicking through the steering too?
#15 turbo boy
turbo boy
  • 1,161 posts
#16 Andy_VX
Andy_VX
  • 2,050 posts
Posted 05 January 2017 - 04:14 PM
"Just" haha it's bitch getting it in / out!
#17 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 05 January 2017 - 04:23 PM
The noise is definitely coming from the middle area of the car not anywhere near the droplinks or ball joints.
I don't believe you can feel it through the steering, just hear it. It drives fine.
Martin
Edited by MartinS, 05 January 2017 - 04:24 PM.
#18 CHILL Gone DUTCH
Posted 05 January 2017 - 04:24 PM
before you go removing anything,
Martin you said the noise continues after you stop rocking the car
I would check the water bottle and fuse box first and maybe even the heater matrix
it could even be a water pipe
#19 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 05 January 2017 - 04:30 PM
If it was an inner track rod, can they be replaced?
Will check other things but from above all seems ok, guess its front undertray off time, to see what visible and checkable, but the noise is just like in that video.
Martin
#20 Andyeddie
Andyeddie
  • 316 posts
  • Interests:Cars, winding up toss pots, grammer, haggis, kilts, football, food, modern archiology, doughnuts, Rootes group cars, Glam rock, The Who, Led Zep, The Stones, INXS, other stuff.
Posted 05 January 2017 - 06:39 PM
Universal joint at the bottom of the steering column.? Mines klunked like a futher mucker, going over anything other than perfect road surfaces, (can anyone remember those), also klunked when I pushed the car from side to side even when stationary, now replaced and all's quiet on the front end now.
Also tagged with one or more of these keywords: any ideas
