Jacking Points For Vx220 Turbo
12 replies to this topic
#1 Ratty5
Ratty5
  • 34 posts
  • Interests:Cars, Motorcycles offroad & road bikes, shooting, meeting up for rallys, Yorkshire VX club memeber
Posted 22 February 2017 - 04:30 PM
Can anyone help please?
I am wanting to jack my car up and remove the wheels to give the car a good clean and service and check pads etc...
When I look on the web there seems to be so many theories on doing this and not sure how sound the advice is.
Do I need to remove all the under tray before i can Jack it up or is it possible while tray is in place?
Any pictures would be great help as I have nothing for reference.
The car is immaculate so it should be easy to work on.
I hope someone can help me out there with this?
Thanks
#2 quimbles
quimbles
  • 760 posts
Posted 22 February 2017 - 04:51 PM
http://wiki.seloc.org/a/Jacking_points
#3 hairy
hairy
    Moonlander
  • 6,003 posts
Posted 22 February 2017 - 09:21 PM
no need to remove tray to take wheels off
#4 Ratty5
Ratty5
  • 34 posts
Posted 23 February 2017 - 08:54 AM
I have no stickers under my car? So is there any other clues to where you put the jack if stickers have been removed?
Thanks
#5 ditonics
ditonics
    Turbos aren’t as good as NA’s
  • 939 posts
Posted 23 February 2017 - 10:33 AM
Might be of use https://youtu.be/x90lFJxwdxY
#6 hairy
hairy
    Moonlander
  • 6,003 posts
Posted 23 February 2017 - 07:44 PM
#7 Raptor
Raptor
  • 942 posts
Posted 23 February 2017 - 07:49 PM
or this:
Attached File  main_jack_point.jpg   85.38KB   31 downloads
#8 ditonics
ditonics
  • 939 posts
Posted 23 February 2017 - 10:39 PM
Are the other jacking points marked with a sticker or just the ones below the doors in the middle?
#9 Raptor
Raptor
  • 942 posts
Posted 24 February 2017 - 07:02 AM
Just the one's below the door.
#10 Raptor
Raptor
  • 942 posts
Posted 24 February 2017 - 07:05 AM
Take my advice with jacking the car: always use a decent bit of wood between the jack and the chassis and watch for the jack moving and slipping off whilst raising. :(
#11 smiley
Posted 24 February 2017 - 07:36 AM
:yeahthat:
#12 hairy
hairy
    Moonlander
  • 6,003 posts
Posted 24 February 2017 - 08:05 PM
No stickers at all on mine, just follow the diagram.
#13 martinroger
martinroger
  • 459 posts
Posted 27 February 2017 - 11:17 AM
No stickers either. Use a piece of wood, look for points where chassis beams join at a right angle :
- Somewhere around the door handle line, ahead of the middle undertray
- At the front wheel attachment point for the suspension, right before the front undertray
- If you remove the rear diffuser, there are two other points where the toe links attach. Use these only as needed.
Also, instead of a piece of wood, I like to use hockey pucks so the jack doesn't slip. It won't crack either.
The rear most points near the toelinks : Posted ImageZF2Y6259.jpg by Martin ROGER, sur Flickr
Posted ImageZF2Y6254.jpg by Martin ROGER, sur Flickr
If you need more pictures, I can provide.
