Mushter, on 22 Mar 2017 - 5:22 PM, said:
Thanks Nev. Castor shims are all over the place as well !!! I can feel a geo session coming on. If visually the camber doesn't look obviously wrong would you suggest I don't reinstall any camber shims initially so I have a base setting to work off ? Cheers, Jon
You can't really "look" to see if the settings dont suit you or the car, you need precise measurements. Even then a setup that suits one person won't necessarily suit another. There is a lot of placebo effect too, owners spend Β£xxx on a geo and then claim it's miraculous, when in fact if you let someone else set it all up again they might find it better again.
As a general rule, setting the car up as OEM (without so called "race"/"extreme" settings is great for road use. All IMO.
Edited by Nev, 22 March 2017 - 07:45 PM.
