Edited by haggi961, 29 March 2017 - 11:58 AM.
Who Would Be Interested In A Set Of Billet Pump Gears?
Posted 29 March 2017 - 11:56 AM
Posted 29 March 2017 - 12:52 PM
Sounds like a good idea, the Z20LET gear is weak too.
Posted 29 March 2017 - 01:04 PM
i would be interested if for NA ??
Posted 29 March 2017 - 03:11 PM
Posted 29 March 2017 - 03:30 PM
Yes I've heard this also. Maybe the later ones are worth trying first before spending more money on parts 😂vocky suggests that the b207 timing chain cover have better gears/pump so they are an upgrade over the z22se ones. Thats all i was going to do.
Posted 29 March 2017 - 03:44 PM
Does the Z22YH also have stronger oil pump gears?
Posted 29 March 2017 - 06:27 PM
I believe it might, think it came out 2004 ish. But not 100% sure on that.
The Neo B207 engines all came with the later spec oil pump
Posted 29 March 2017 - 06:39 PM
Posted 29 March 2017 - 09:35 PM
Contrary to what we used to believe, the "GM Racing" gears are not billet, but just OE ones hardened.
When I had my old engine built, I had spare sets hardened by the same process other manufacturers uses, which worked great as I didn't saw any kind of piting as I had on my OE gears.
This may be a lot cheaper to do if you want to.
On the other hand, the Sodemo BTCC engine had billet gears, thinner than the OE ones (less flow), and a reduced oil pressure.
Posted 29 March 2017 - 09:55 PM
Myself if for NA. Actually any ITBd car owner should be interested, as our cars rev to 7800 by default.
But then I have currently a Z22YH pump installed and another brand new B207 one as spare already. The joy of endless spare parts hoarding...
Posted 29 March 2017 - 10:45 PM
Any more details on a specific hardening process for the gears?
Posted 29 March 2017 - 11:39 PM
Yes il would be interested in knowing this please and the type of metal used on the gears?Any more details on a specific hardening process for the gears?Contrary to what we used to believe, the "GM Racing" gears are not billet, but just OE ones hardened. When I had my old engine built, I had spare sets hardened by the same process other manufacturers uses, which worked great as I didn't saw any kind of piting as I had on my OE gears. This may be a lot cheaper to do if you want to. On the other hand, the Sodemo BTCC engine had billet gears, thinner than the OE ones (less flow), and a reduced oil pressure.
Posted 30 March 2017 - 09:49 AM
I do not know the English name of it.
From what I understood, it is done by inclusion of water stem one the part heated at high temperatures
The mates explained it is what is used by OE manufacturers and that is basically almost doubles the surface hardness. I even had the hardness data at the time, but not sure I still have it.
Posted 30 March 2017 - 09:57 AM
Posted 30 March 2017 - 10:05 AM
On the Z20LET gear there are 2 issues that I know of:
1. The side of the gear errodes into the side of the housing causing some play.
2. The gear shatters completely into 2 or more bits.
I think nitdriding (or some other surface treatment) would only help with point 1 above, but not with point 2. The whole thing needs to be made stronger to stop it shattering.
Posted 30 March 2017 - 09:48 PM
Don't sbd sell some unicorn horn oil pump bits for the xe/letOn the Z20LET gear there are 2 issues that I know of: 1. The side of the gear errodes into the side of the housing causing some play. 2. The gear shatters completely into 2 or more bits. I think nitdriding (or some other surface treatment) would only help with point 1 above, but not with point 2. The whole thing needs to be made stronger to stop it shattering.
Posted 31 March 2017 - 07:26 PM
Yep, they do/did.
