Is there a way round this with your dash? It's so annoying with my digital dash now that the alarm won't sound when I've left my lights on. Fitting a alarm buzzer to the headlight switch/door popper doesn't work.Sorry , headlight noise is gone .Another question is does the headlight noise sound when you leave the lights on and open the door? I know the the VX signals to earth when the doors are shut rather than the opposite so it's a pain trying to get anything to work here.
Lcd Instrument Cluster In A Vx
#61
Posted 31 March 2017 - 09:10 AM
#62
Posted 31 March 2017 - 09:13 AM
Use the can output of the ecu for all its data Do s the omex have canTo add more detail to this - I am moving to the Omex 600 ECU for my Webcon throttle bodied car in May and it is capable of being configured to output 1 PWM frequency of either 250, 125, 84 etc but not 100 which is what the Stack temp gauge uses. However, thinking about this, if we are taking out the Stack dash, do we even need PWM for this? The Webcon kit has two water temp sensors and I wonder if we can hook into either one of these to feed the new LCD dash?
The averaging of the analogue value will represent the duty cycle % in the same way . I used the Elise S2 k series to work out the pwm , which seemed pretty linear when tested with a pwm input to the cluster . I will test the original vx clusters temp reading vs pwm input .
The vx220 Pwm output from the ecu is not linear in its behaviour so while the average value will give something, it won't represent the actual temp. There is a thread a page or so in from here with a link to some scope readings from it
I choose to average the analogue value from the pwm instead of measuring the duty cycle of the pwm This allows it to work with both analogue and pwm inputs , What would be reason to change the frequency ? More background to the question please :-)Could the PWM input for the temp gauge be configured to work at a different frequency?
#63
Posted 31 March 2017 - 09:16 AM
#64
Posted 31 March 2017 - 09:21 AM
I would imagine that the Omex PWM output will be linear and proper, so I'd stick my neck out and say that based on Garw's posts, it will read that just fine.
Its the stupid relationship of the temp to PWM form that the VX/Mk4 astra ECU has that might post some inaccuracies for standard folks. The likely reality is that it wont matter that much for 95% of users
#66
Posted 31 March 2017 - 09:30 AM
Another wonderful VX mod for which I really have no need, but a whole lot of want..
#67
Posted 31 March 2017 - 09:45 AM
Not sure what the issue is here , i need to confirm the door switch states first , as i was sure its a normally closed switch
#69
Posted 31 March 2017 - 09:51 AM
could it work with a sat nav screen to ?
#70
Posted 31 March 2017 - 10:03 AM
This looks very good, I've always wanted a proper display that looks a bit more OEM. I'll follow progress with interest.
#71
Posted 31 March 2017 - 10:19 AM
If you can figure this out I would be interested in one as this would temp me 😁Not sure what the issue is here , i need to confirm the door switch states first , as i was sure its a normally closed switch
#72
Posted 31 March 2017 - 10:29 AM
For a visual guide the non linear behavior is not important
the range we are interested in is linear and the fact the maths are wrong under 50 Deg C and over 110 doesn't matter
ecu's need to get it exact across the full temp range as this data is very important for fueling correctly at all times.
I will scope the VX between the visual range and see what error exists if any
#73
Posted 31 March 2017 - 10:38 AM
#74
Posted 31 March 2017 - 11:01 AM
#75
Posted 31 March 2017 - 11:13 AM
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]1. Rusty789[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]2. Raptor (8" screen)[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]3. chickendippers (8" screen)[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]4 leevx2.2 8" screen [/color]
I like the idea of being able to cast sat nav etc from my phone to the screen.
#76
Posted 31 March 2017 - 11:40 AM
1. Rusty789 2. Raptor (8" screen) 3. chickendippers (8" screen) 4 leevx2.2 8" screen
5.Stig_1911
#77
Posted 31 March 2017 - 12:06 PM
the door switches simply connect to ground. A buzzer with a 12v sourched from the lights power and switched to ground by the doors does the job. All needed connections are at the dash connector. https://www.speedste...tact switch.pdf
Edited by Exmantaa, 31 March 2017 - 12:13 PM.
#78
#79
Posted 31 March 2017 - 12:32 PM
I've fitted 3 different types of buzzers with this method and after a couple of days the buzzers break and stick on making the alarm sound.the door switches simply connect to ground. A buzzer with a 12v sourched from the lights power and switched to ground by the doors does the job. All needed connections are at the dash connector. https://www.speedste...tact switch.pdf
#80
Posted 31 March 2017 - 12:33 PM
This is EXACTLY what i am looking for since a few weeks...
Please give more details about that analog-CAN converter box!
I need do have displayed:
- RPM up to 8000
- speed
- fuel tank
- engine coolant temp
- Lambda (comes from wideband controller als 0-5V signal)
- oil pressure (VDO sensor)
- oil temp (VDO sensor)
- boost (0-5V signal)
not a need but would be cool to display:
- Exhaust gas temperature
- amount of injected water (comes from the controller als 0-1V signal)
- gearbox-temp (2nd oil temp sensor)
You can put me on the list if you can display this things and the price is that 600 GBP.
