Lcd Instrument Cluster In A Vx
382 replies to this topic
#141 ultimate
ultimate
  • 261 posts
Posted 04 April 2017 - 05:30 PM
Yes, makes sense to me. Which brand of analog oiltemp and oilpressure sensor do I need? What do you think how long do you need to bring that expansion-box?
#142 garw
garw
  • 125 posts
Posted 04 April 2017 - 06:56 PM
Expansion box is a quick turnaround, the release will wait for the testing of LCD cluster testing to be done . So after release of the cluster the box will follow about 4 weeks later . I don't have a particular sensor to recommend, I would assume the sensors sold by Elise websites Have been proven , ensure the oil pressure sensor is fitted on a remote oil line to reduce vibrations They are mechanical devices and vibrations will cause erratic readings and significantly Reduce its life I won't provide links to sensors in order remain neutral on products which are not my own . I think that's the forum rules for people like me .
#143 ultimate
ultimate
  • 261 posts
Posted 04 April 2017 - 07:03 PM
I am just asking because I think different brands will have different values/resistance-curves. For example: sensor a has 1000ohm at 100 degrees and Sensor b has 800ohm at 100 degrees
#144 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 04 April 2017 - 07:44 PM
As long as the output is reasonably linear (over the operating range) I'd assume this doesn't matter and you'll be able to set it up as y = f(x) + c Amazing work. Keen to hear more details on the logging when you get a chance. I.e. Are ALL inputs logged? (Standard such as rpm and the 16 analogue inputs if the extra box is purchased?) Are calculated values logged? (G-force etc) What frequency are they logged at? >10Hz would be cool
Edited by Chris P Duck, 04 April 2017 - 07:46 PM.
#145 garw
garw
  • 125 posts
Posted 04 April 2017 - 07:47 PM
ok
gauge type oil pressure sensors which have a 3-160 ohm range     for 0-10bar   are good
oiltemp sensor should be gauge type
gauge type sensors have a lower resistance to ecu type
the 1000 and 800 ohms at 100 deg are too high
100 deg should be under 100ohms
VDO gauge type for example would be around 50 ohms at 100 deg
#146 garw
garw
  • 125 posts
Posted 04 April 2017 - 07:53 PM
The current datalogging implementation logs everything including gps coordinates and 3 axis gsensor (built in) its set to 10hz (just thought its was a good place to start)
the data channels are logged not the sensors themselves ,  ie throttle position value is logged 0-100%   not the analogue input its connected to ,  as it could be from the canbus.
gforce is logged in G's
#147 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 04 April 2017 - 07:58 PM
  The current datalogging implementation logs everything including gps coordinates and 3 axis gsensor (built in) its set to 10hz (just thought its was a good place to start)   the data channels are logged not the sensors themselves ,  ie throttle position value is logged 0-100%   not the analogue input its connected to ,  as it could be from the canbus.   gforce is logged in G's
Thanks, I'd assumed G-force was calculated from the GPS rather than measured from a sensor. This really is good value when you compare it to a race logic performance box and micro-input module (which is what I currently have) Just a thought on expanding your market. Is all the hardware already there for recording track footage with a data overlay?
#148 ultimate
ultimate
  • 261 posts
Posted 04 April 2017 - 08:00 PM
ok   gauge type oil pressure sensors which have a 3-160 ohm range     for 0-10bar   are good   oiltemp sensor should be gauge type   gauge type sensors have a lower resistance to ecu type   the 1000 and 800 ohms at 100 deg are too high    100 deg should be under 100ohms   VDO gauge type for example would be around 50 ohms at 100 deg
Will the "translation" (resistance = shown value) be programmable by the user himself? I had three different gauge oil temp sensors in the last years. All had different resistance at the same temp. Cheers
#149 garw
garw
  • 125 posts
Posted 04 April 2017 - 08:20 PM
Yes
#150 garw
garw
  • 125 posts
Posted 04 April 2017 - 08:22 PM
Maybe , when the video input is sorted then it could be looked at .
#151 ultimate
ultimate
  • 261 posts
Posted 04 April 2017 - 08:30 PM
Okay, so for the records ;-) : I found the following values for VDO Sensors: Oiltemp for 150 degree Sensor: 60°C - 221,2 Ohm 90°C - 83,0 Ohm 120°C - 36,5 Ohm Oilpressure for 0-10bar Sensor: 0 bar - 10 Ohm 2 bar - 52 Ohm 6 bar - 124 Ohm 10 bar - 184 Ohm
Edited by ultimate, 04 April 2017 - 08:31 PM.
#152 ultimate
ultimate
  • 261 posts
Posted 05 April 2017 - 06:40 AM
found more values for the oiltemp-sensor.
Like every NTC it is not linear, see attached image FYI ;-) Is this non-linearity a problem for the cluster?
Edited by ultimate, 05 April 2017 - 06:45 AM.
#153 ultimate
ultimate
  • 261 posts
Posted 05 April 2017 - 06:42 AM
Oilpressure is linear.
#154 garw
garw
  • 125 posts
Posted 05 April 2017 - 06:38 PM
For the area we are interested in the curve should be linear enough for accuracy In that range .
#155 ultimate
ultimate
  • 261 posts
Posted 05 April 2017 - 07:21 PM
Which range do you mean?
#156 garw
garw
  • 125 posts
Posted 05 April 2017 - 08:07 PM
80-120 deg c Oil temp gauges usually start at 50-60 deg c and go upto 140
#157 garw
garw
  • 125 posts
Posted 05 April 2017 - 08:14 PM
#158 garw
garw
  • 125 posts
Posted 05 April 2017 - 08:17 PM
There is no technical reason why non linear inputs cannot be used I aim to keep the product as simple as possible , so unless there is a real need to Use the full range of the sensor I will keep it simple for now.
#159 ultimate
ultimate
  • 261 posts
Posted 05 April 2017 - 08:57 PM
I am with you to keep it simple for the beginning!
But I think the oiltemp-gauge will become useless when using a linearity extrapolated from the 80-120deg area.
please have a look at the attached image:
In this case you will never see overheating because even at 180deg (10 Ohm) the extrapolated output will show just 135 deg.
And for warming up:
70deg (155 Ohm) will be shown as 55
Please don't think i will speek your product ill or something. I just want to give you my thinking as an input to optimize it.
Edited by ultimate, 05 April 2017 - 09:01 PM.
#160 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 06 April 2017 - 01:47 PM
Could you use something like a LTC2997 between the sensor and cluster?
