Spoke to Jimmy and he says he thinks some bias control is within the ABS block. If that's the case then I'd need to fit a biasvalve. I'm not sure I want to use qualifying as a test session :/
VX == same identical brake calipers and disc sizes as Elise S1 and S2
Un-assisted S1 and S2 Elise == no bias valve at all, straight-bore MC
Unless the VX MC has a stepped bore then it should have the same brake balance/behaviour as a regular Elise when the ABS unit is completely removed and the pipes connected to the MC directly.
Only difference remaining between the VX and an S1 or Rover-S2 Elise when taking out the ABS is the vacuum assist and different MC as a result. VX uses a bigger bore MC as the vacuum assist helps with the pedal effort.
If the vacuum assist is (also) removed on a VX then you must (retro)fit the non-assisted MC from an Elise or you end up with a rock-hard pedal and little brake retardation on the VX.
Feel may be a little different as the VX pedal box has slightlly different pedal pivot points/ratios than the original extruded ali Elise pedal setup, but that should not be too severe.
