Really Simple Question....
shocks suspension
11 replies to this topic
#1 DX220
DX220
  • 326 posts
Posted 24 July 2017 - 08:13 PM
...but can I find the answer for love or money?
I have some Nitron street series on on VXT
Am happy with the overall front - rear balance (mild over-steer) but the front feels too bouncy, particularly noticeable in fast corners.
So, I want to try increasing rebound settings (prob all round).
Here's the question: does clicking towards '+' to increase rebound, bump or both?
I said it was a dumb question!
Have seen lots of advice about settings, have googled the manual however.....
#2 CHILL Gone DUTCH
Posted 24 July 2017 - 08:19 PM
try reducing your tire pressures
#3 Nev
Posted 24 July 2017 - 08:38 PM
That's an excellent question, and I bet 95% of people who buy these as an "upgrade" wouldn't know the answer, or how to set them up etc, or how they compare to the carefully selected OEM (Lotus specified) ones. I know I didn't when I first bought my car and it understeered quite a bit.
To try and answer your question, I have some very old Nitron 40 coilovers on my VX (which may differ from your NTRs), but on mine I was told (by a Nitron employee) the knob affects bump but there is a 1:2.5 ratio between bump and and rebound (so to be clear, in effect it affecting both).
It's quite possible to reduce eliminate the oversteer you have with subtle geo changes BTW (mainly with toe and ride height changes).
Over the years I think the valving on Nitrons in general has changed a bit, so I get the feeling some Nitrons XXX models are not the same as others.
Edited by Nev, 24 July 2017 - 08:58 PM.
#4 pete-r
pete-r
  • 2,771 posts
Posted 24 July 2017 - 08:45 PM
Both
#5 DX220
DX220
  • 326 posts
Posted 25 July 2017 - 08:47 PM
Thanks gents - that about covers everything!  thumbsup
CHILL:
didn't think my pressures were that high
Think it's 25/27 in 16"/17" Speedlines (not the fancy Mag ones) but must check/experiment
Nev:
Thanks for making me fell better about my ignorance
Mild over-steer, controllable by right foot; guilty pleasure  :D
Pete-r:
Appreciated
#6 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 25 July 2017 - 08:58 PM
If its bouncy try putting clicks on. Bouncy = leaning on the springs too much. Dampers not doing enough damping.
#7 pete-r
pete-r
  • 2,771 posts
Posted 25 July 2017 - 09:07 PM
No problem, JB makes a good point. Remember the springs want to keep going boing boing and the damper stops them. If you under dampen the car significantly then the springs are going to do just that. Conversely if your over damped then the springs won't be strong enough to decompress to a normal ride height and your car will gradually lower itself to the ground ;) If you wind the shocks up to full stiff, then count back the number of clicks and make notes as you do before test driving. Rule of thumb is a couple of clicks stiffer at the rear because of the weight of the engine. Then you can start to play with the settings and see what you like. Personally I wouldn't DIY it beyond playing. If you take the car to a good specialist they can set the geo and damping together for whatever sort of style you want.
#8 chris_uk
Posted 26 July 2017 - 07:11 AM
just check the shocks for leaks as well..
#9 Exmantaa
Posted 27 July 2017 - 08:38 PM
What spring rates do you have?
#10 DX220
DX220
  • 326 posts
Posted 29 July 2017 - 09:01 PM
So the plan: aim to replace MAF tomorrow, and then see how a couple of extra clicks feel
I was afraid someone would ask that one!  :mellow:
Dunno!
Bought secondhand awhile ago, and if I asked that information; don't know what I've done with it?
Will have to look up how to check for leaks
#11 oakmere
oakmere
  • 2,143 posts
Posted 30 July 2017 - 08:10 PM
I found too many clicks on the front gave the car a high frequency bounce. It kind of looked like the front of the car skipped along as the shock absorbers were no longer absorbing due to being too stiff. If the car keeps bobbing after undulations then they are too soft i.e. they are not controlling the springs.
#12 DX220
DX220
  • 326 posts
Posted 01 August 2017 - 09:40 AM
Springs now appropriately tamed.
Needed more damping  :tt:
Thanks all  thumbsup
Now then, where's that summer gone..........
Also tagged with one or more of these keywords: shocks, suspension
