Handbrake Cover (some scratches) £10.00
Handbrake/Gear Linkage Assembly £80.00
Speaker Panel Cover £40
Dashboard inc Vents (VGC - car done 43k) £120.00
Pair Rear Plastic Roof Bar Brackets £20.00
Pair Rear Diecast Roof Bar Brackets £15.00
Pair Front Diecast Roof Bar Brackets £15.00
Pair Alloy Stalks only (NEW) - pushes onto OEM stalk £25.00
Pair OEM Stalks £14.00
Wiper Stalk (back cover missing) £5.00
Alloy Bootlid Release Bracket £5.00
Alloy Bonnet Release Bracket (fits under-dash) £12.00
Plastic Roof Bar plugs - set of 4 £8.00
Drivers OEM Mat £25.00
Pair Lotus Mats £40.00
Wiper Arm £15.00
Pair Front Splitters (scuffs) £25.00
Steering Rack £100.00
O/S DriveShaft £80.00
N/S Driveshaft £80.00
VXT Starter Motor £10.00
NA Starter Motor £10.00
VXT Belt Tensioner Pulley £8.00
Inner Door Seals (each) £5.00
N/S Black Door Trim Panel (MINT) £65.00
N/S Black Door Trim Panel (VGC, some seatbelt indents) £40.00
O/S Black Door Trim Panel (MINT) £65.00
VXT Main Wiring Loom £200.00
NA Main Wiring Loom £200.00
Aluminium Dash Panel (dash plates & heater dials bolts onto) £50.00
VXT Inlet Manifold £15.00
VXT Injector Rail & Injectors £65
VXT Throttle Body £45.00
Central Locking Set with steering column cover & switch (Secondhand door motors, pins, wiring, module, steering column cover, NEW Battery & Cover) £250.00
Black Plastic Door Ovals (Some clips missing) - each £5.00
Pair Black Plastic Mirror Housing Inner Moulds £12.00
Boot Stay £12.00
NA Injector Rail & Injectors £30.00
2.0 Turbo Coil Pack Cover £16.00
N/S Radiator Hose (with bleed nipple) £30.00
O/S Radiator Hose (no bleed nipple) £14.00
Oil Radiator Hoses various
O/S Headlight Cover (NOT the lens, the black plastic inner cover fitted to later VX220's) £65.00
O/S Turbo Sill Pocket £25.00
Steinmetz Copy (Brand New, never fitted, in bag with fixings) £230.00
O/S NA Rear Light £300.00
N/S NA Rear Light £300.00
NA Downpipe & Cat £100.00
NA Short Decat Pipe £50.00
NA Exhaust Manifold £45.00
NA Inlet Manifold £45.00
Turbo 36k (like new) 90423508, KO4-024FE 5052477 £300.00
Turobo 70k (small amount of play) 55 559 850 JE50116891 00136 5304 9700049 £200.00
Turbo 28k (has an amount of play) £150.00
Roll Bar £40.00
O/S NA Side Air Intake Grill £17.00
Engine Bay Bulkhead Soundproofing Panel £30.00
Steering Column Cover £20.00
Pair Black Leather Door Pads (N/S Ex.Cond, foam slight split on back - not visible from front, O/S small indent mark and scuff to leather) £35.00
O/S NA Sill Cover (Ex.Cond) £120.00
N/S NA Sill Cover (crack at front curved piece, ideal for covering or can be glued) £40.00
N/S NA Sill Cover (minor crack at side, can be glued or covered) £50.00
N/S VXT Sill Cover (VGC,) £110.00
OEM Soft Top Roof Bag £15.00
Soft Top Liner (aftermarket item aids warmth) £30.00
Pair Headrest Pads (VGC, odd minor indent mark) £30.00
Pair Headrest Pads (minor marks) £40.00
O/S Plastic Headrest Cover (Ex.Cond) £20.00
Various Fuel Pipes & Hoses Various
O/S Turbo Ear, Black (no black insert) £100.00
Pair Dash plates (painted black) £30.00
4 x Opel Centre Wheel Caps (Ex.Cond) £25.00
Set of 4 polished carpet mat screws with bases £25.00
Polished aluminium handbrake cover £15.00
polished aluminium gear knob £20.00
polished aluminiun window winders (PAIR) £30.00
Handbrake Primary cables (the one in the white sleeve) £8.00
Handbrake Cable (complete) £35.00
OSF Hub (bolt version type) £45.00
NSF Hub (bolt version type) £45.00
OSR Hub £60.00
NSR Hub £60.00
OSF Lower Wishbone £95.00
Pair Anti-Roll Bar Aluminium Brackets £10.00
Front Engine Mount (9197998) £30.00
Rear Engine Mount (9197995) £25.00
Front Engine Mount Bracket (9197629) £20.00
RH Engine Mount Bracket (9197997) £20.00
LH Engine Mount Bracket (9197994) £20.00
Rubber Engine Mounts (VGC,93172350) - each £30.00
Lower Wishbone to Chassis Bracket RH (9197869) £25.00
Lower Wishbone to Chassis Bracket LH (9197868) £25.00
Air Heater Housing Distribution £35.00
VXT Airbox £40.00
VXT Airbox (holes drilled in bottom) £30.00
VXT Airbox (Brand New) £60.00
NA Airbox (lid only) £20.00
NA Radiator £50.00
Radiator Fan & plug £40.00
Damaged Radiator Housing (ideal for repair/parts) £40.00
Radiator Housing (aftermarket, small previous repair) £140.00
Radiator Housing (OEM, 2 holes cut for brake cooling) £250.00
Rear Subframe £550.00
Various Front Clam sections (ideal for repairs etc) Various
Airbag (VGC) £100.00
Airbag (some minor scratches) £80.00
N/S Door Glass £80.00
O/S Door Glass £80.00
VXT Footrest (Brand New) £140.00
Steering Wheel (some minor marks, VGC) £90.00
Airbag Module £20.00
Airbag Squib £35.00
Seatbelts - PAIR £150.00
Seatbelt - Need to Confirm which side £75.00
Bonnet Hinge £45.00
Undertray Black Plastic Ducts - each £8.00
Door Lock Catch Mechanism RH & LH - each £12.00
NA Pair Bootlid Hinges £15.00
VXT Pair Bootlid Hinges £15.00
Aerial £6.00
Heater Panel with 3 Dials & cables £45.00
Towing Eye Bracket (good, some rust patches) £40.00
NA Footrest £40.00
Set of 4 Floor Mat Screws & Bases £25.00
Pair Rear Clam Wheel Arch Spats (Painted Blue) £70.00
N/S Fog Bracket £22.00
Passenger Seat Handbook Stowage Pocket £8.00
Pair Canvas Sill Pockets £45.00
VXT Engine Loom (both pieces) £150.00
NA Engine Loom £80.00
Aerial Base & Aerial (VGC) £15.00
NA Throttle Body £45.00
Clutch Return Spring £3.00
Grey Relay £8.00
Brown Relay £8.00
Washer Bottle £4.00
Washer Bottle Pump £6.00
Rear Brake Light (VGC) £35.00
Rear Brake Light (1 clip broken) £20.00
Knock Sensor NA (12567711)- OEM £12.00
Knock Sensor VXT (90541521)- OEM £18.00
Inertia Switch £5.00
Interior Light £5.00
Pair Numberplate lights £8.00
VXT Brake Switch £15.00
NA Brake Switch £12.00
Starter Button & wiring £22.00
Starter Button & wiring (aluminium button missing) £16.00
Centre Wheel Cap with Griffin badge £10.00
Coolant Level Sensor £10.00
Pair Washer Jets £8.00
Towing Eye (small hole) £12.00
Towing Eye (aftermarket, aluminium) £20.00
MAP Sensor - OEM £22.00
OEM Heater Box £90.00
Ignition Switch £25.00
N/S Interior Footwell Covers (little black plastic caps behind footrest) £3.50
Set of 3 Roll Bar Cover rubbers (access holes for brake light & aerial) £3.00
Bootlid/Bonnet Rubber Stops with bolts (4 long, 1 short) - each £3.50
NA Exhaust Manifold Heatshield £15.00
VXT Driveshaft Heatshield (some rust) £20.00
NA Driveshaft Heatshield (some rust) £20.00
NA Oil Radiator £130.00
ABS Complete Hydraulic Control Module £75.00
Silver Roll Bar Cover (VGC, some minor storage marks) £35.00
Exhaust Wrap-around heatshield (been cut on side at some point to fit exhaust but perfectly useable) £35.00
Exhaust Wrap-around heatshield (rivets come away, needs attention) £15.00
Roll Bar Cover, Rabiata Red (some surface scratches) £35.00
NA Boot Carpet £28.00
VXT Boot Carpet £28.00
NA Boot Carpet Padding £10.00
VXT Boot Carpet Padding £10.00
Washer Bottle/Battery Bracket £15.00
Horn £2.00
O/S Mirror (Metallic Black, chips to base, minor scratches) £35.00
N/S Mirror (Calypso Red, chips, scratches) £25.00
N/S Mirror (Rabiata Red, no glass, needs painting) £15.00
O/S Mirror (Black, needs painting) £25.00
N/S Blue Mirror Base £8.00
O/S Mirror (Silver, Good) £35.00
N/S Mirror Base & Cover (no glass or black glass frame surround) £12.00
N/S Mirror (Good) £35.00
O/S Mirror (Calypso Red, scratched) £30.00
Alarm Shock Sensor (fits behind Speaker Panel) £4.00
Pair Window Winders £30.00
Top Boost Hose (Like New) £45.00
Top Boost Hose (outer sleeve split) £5.00
MAF - 0280 218 051 Bosch £45.00
MAF - Brand New £70.00
ITG £180.00
ITG - Silver Bracket Missing £160.00
Bonnet Release Handle & Cable £22.00
Bonnet Release Handle, Cable & Aluminium under-dash bracket £26.00
Window Guide Rails with adjusters - Pair £18.00
Window Winder Mech Regulators - Each £35.00
Door Hinge & Bar (Dent on end of Bar but Hinge itself good, and its that bit which wears) £30.00
NA Exhaust Backbox & U-bend (U-bend cut at end) £40.00
OEM Crashbox (Ex.Cond) £650.00
Pair Aluminium Dash plate end caps NA (the 2 black plastic curved trim when door is open) £6.00
Wiper Motor Cover £12.00
Boot Relay Cover (square type) £8.00
Boot Relay Cover (curved type) £8.00
Exhaust Blue Rubber mount brackets (with metal piece) - each £3.50
Aluminium Centre Console Tunnel £8.00
Aluminium Centre Console Foot Rest £8.00
VXT Airbox Bracket £8.00
VXT Coolant Tank Bracket (painted blue) £10.00
VXT Coolant Tank Bracket (some rust) £8.00
NA ECU, Transponder & Chip £150.00
NA Clocks (approx 70k) £150.00
NA Clocks (approx 43k) £150.00
Set of Door locks, ignition barrel & 1 key £90.00
N/S Door (rubbed ready for painting, was silver - can sell complete or shell) Ask
O/S Door (rubbed ready for painting, was silver - can sell complete or shell) Ask
Pair Front Calipers (refurbished & painted red - no pistons) £220.00
Brake Master Cylinder, Servo & Reservoir £85.00
OSF Caliper (painted Red, Good) £125.00
Track Control Arm £18.00
Track Control Arm x 2 (needs new ball joints) £8.00
OSR Lower Wishbone £95.00
NSR Upper Wishbone (Brand New) £140.00
NSR Upper Wishbone £90.00
OSR Upper Wishbone £90.00
O/S Steering Arm £30.00
Drop Links x 4 (from anti-roll bar) - each £5.00
100amp Alternator (90561971) £25.00
120amp Alternator (09131264) £25.00
Complete Set of Pedals with aluminium plates £120.00
Set of 3 Aluminium Pedal Treads with black studs - Polished Aluminium (Like New) £40.00
NA Wiper Motor & Bracket £70.00
Pair Shock Mount Brackets £22.00
O/S Shock Mount Bracket £12.00
Long Dash plate silver (as new) £30.00
Intercooler Duct (Black Plastic, fits behind Turbo Ear) £8.00
Polished Aluminium Centre Console Tunnel £15.00
Stack Surround (usual crack across top, good for recovering) £18.00
Pair VXT Floor Mats £45.00
Full set of Touring pack carpets & mats (optional upgrade, includes side sill carpets, 4 floor carpets (2 under seats, 2 front footwell carpets - fits under floor mats), Set of 4 longer Floor Mat Screws & bases (fitted to cars with the touring pack as thicker carpets) & Pair of VXT Touring Pack Floor Mats (very thick, plush black carpet, different to the standard mats) £140.00
Stack Surround (Good, no cracks) £35.00
N/S VXT Headlight (lens replaced, some minor marks, usual brackets broken underneath) £350.00
Pair NA Mats £45.00
Aftermarket Hardtop (in primer, lined in black & orange, can be removed) £225.00
Rear Centre Griffin Badge £15.00
MMG Rear Diffuser (some damage, would need a little paint) £140.00
NA Gear Linkage Cables £160.00
NA Gear Linkage Cables (end connector broke, cables good) £90.00
VXT Gear Linkage Cables £160.00
Front Anti-Roll Bar (some minor rust) £40.00
Front Anti-Roll Bar (Brand New) £70.00
NA Gearbox (cracked case, good inners) £60.00
VXT Gearbox (bad inners, good case) £60.00
NA Bootlids (various colours) £40.00
VXT Bootlids (various colours) £80.00
VXT Bootlid, silver, no pin £70
Front Bonnet (Calypso Red, bonnet pins, centre pin removed weight reduced & hinge removed, ideal for racing) £30.00
VXT Bootlid (Silver, no pin) £35.00
Drivers Side Biscuit Seat (minor bolster wear, on passenger seat rail) £140.00
Pair Black Leather Seats (usual Drivers bolster wear) £230.00
Pair Black & Light Blue Seats, door cards & door pads (VGC), tiny bit of damage to Drivers Door Pad car done 28k £450.00
Full reupholstered interior, 'Carbon Fibre' look Black & Orange NEW, NEVER FITTED (pair seats, Door Trim panels, Door Cards, Door Pads, Centre Console, Cup Holder, Headrest Pads, Black Dash plates & Door Triangles) £650.00
Silver Centre Console, marks (ideal for recovering) £35.00
Cup Holder (VGC, some seat marks) £22.00
Cup Holder (tatty, ideal for painting/recovering) £8.00
Pair Black Leather Door Pads (VGC, tiny mark) £45.00
Driver Side Biscuit Leather Door Card (Brand New & wrapped) £45.00
Rear Lights Wiring Loom £35.00
Top Lambda Sensor £18.00
Lower Lambda Sensor £18.00
Bilstein Shocks (spring collars corroded, ideal for refurb) Ask
Pair Rear Wheel Arch Liners (rear piece cut to release air through lower clam vents) £60.00
Various Broken Rear Clams & Sections (Ideal for pieces or repair sections) Some are complete rear clams with damage Ask
VXT Engine Head Ask
VXT Engine Block Ask
Repaired OEM Front Clam (needs usual prepwork prior to painting and headlight bracket re-attaching) £500.00
OEM Fuel Tank £50.00
OEM Fuel Sender Unit £120.00
NA Complete fibreglass Sill - N/S (VGC) £135.00
NA Complete fibreglass sill - O/S (previous repair) £100.00
VXT Complete fibreglass sill - O/S Black £125.00
Pair Aluminium Sill Protectors, small OEM 'Turbo' £40.00
Pair Aftermarket Aluminium Sill Protectors, large (Brand NEW) £50.00
Steering Column with Steering Wheel Hub £80.00
Lower Steering Bar & Knuckle Assembly £25.00
Large Middle Undertray (NA Version with Hatch) £70.00
Standard Rear Diffuser £45.00
Fuel Tank Shear Panel Undertray £60.00
Cat B undamaged chassis, with Windscreen, rear window, roll bar & NA Fibreglass Sills (ideal for race-car etc) £600
Leather Centre Console from a VXT £125
VXT Footrest £80
N/S Outer Door Seal (VGC, tiny bit of bubbling to the end, low ,mileage car) £30
VXT engine 70k, with service book - without ancillaries £900
NA engine, 28k, no service book - without ancillaries £650
I hand heard both running, both are sweet with no smoke or knocking
VXT engine, 30k, no service book - no ancillaries - will be splitting as not heard running - ask for details
Rear VXT clam, VGC, no damage, blue, £900
VXT rear spoiler, VGC, blue OEM - £140
NA O/S front headlight, excellent condition £600
VXT N/S front headlight, good condition, usual clips broken underneath £350
Please contact me for any other parts you need as we have most things
All prices are plus postage, I will try and keep most items as cheap as possible and send second class, and of course combine postage if you buy more than 1 thing. If you are interested in a couple of things I will try and do a discount for you too. Larger items by courier. Some items such as clam etc would be collection only
I am happy to send a picture of any of the parts you are interested, just drop me a message with your email address and I will send them over
Various Parts For Sale
Posted 28 August 2017 - 09:48 AM
Posted 28 August 2017 - 09:59 AM
Posted 28 August 2017 - 10:00 AM
hi the postage would be £4
Posted 28 August 2017 - 11:44 AM
Posted 28 August 2017 - 12:26 PM
you got a dash starter button please ?
Posted 28 August 2017 - 02:28 PM
Posted 28 August 2017 - 03:25 PM
Can I have the [color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]N/S and OS Black door trim panels [/color][color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;](MINT) £65.00 [/color]each?
Also interested in the door pad shoulder pads - but could do with a pic of those if you can
cheers
Posted 28 August 2017 - 03:36 PM
Iain richings, on 28 Aug 2017 - 2:28 PM, said:
100amp alternator please
pm sent
cheers
Hi sorry someone has already asked for the door trim panels. I will check for others but usually they have some seatbelt indents in
which door pads? I have 2 sets listed?
Can you also send me your email address for pics please
Posted 28 August 2017 - 03:43 PM
Posted 28 August 2017 - 04:03 PM
Posted 28 August 2017 - 04:40 PM
hi Paul
postage would be £6.50
Posted 28 August 2017 - 04:58 PM
Posted 28 August 2017 - 06:55 PM
Posted 28 August 2017 - 07:56 PM
Posted 28 August 2017 - 09:21 PM
Posted 29 August 2017 - 12:39 AM
