M18 FPP2W-502X - Ref # 4933459756 M18 FUEL™ PERCUSSION DRILL
More power - unmatched torque of 135 Nm
All metal reversible belt clip - hang your tool quickly and easily
Flexible battery system: works with all Milwaukee® M18™ batteries
More speed - delivers up to 2000 rpm
Smaller size - length of just 197 mm
Milwaukee® designed and built brushless POWERSTATE™ motor for up to 10x longer motor life and up to 60% more power
REDLINK PLUS™ intelligence system delivers an advanced digital overload protection for tool and battery and uniquely enhances the tool performance under load
REDLITHIUM-ION™ battery pack provides superior pack construction, electronics and fade-free performance to deliver more run time and more work over pack life
Individual battery cell monitoring optimises tool run time and ensures long term pack durability
Battery fuel gauge displays remaining charge
Brightest LED workspace illumination
RANGE SPEC - M18 FPD-502X
[font="helveticaneuemed, serif;"]Article Number 4933451062[/font]
[font="helveticaneuemed, serif;"]Battery pack capacity (Ah) 5.0[/font]
[font="helveticaneuemed, serif;"]Battery type Li-ion[/font]
[font="helveticaneuemed, serif;"]Charger supplied 59 min[/font]
[font="helveticaneuemed, serif;"]Chuck capacity (mm) 13[/font]
[font="helveticaneuemed, serif;"]Max. drilling masonry (mm) 13[/font]
[font="helveticaneuemed, serif;"]Max. drilling steel (mm) 16[/font]
[font="helveticaneuemed, serif;"]Max. drilling wood (mm) 65[/font]
[font="helveticaneuemed, serif;"]Max. percussion rate (bpm) 0 - 32,000[/font]
[font="helveticaneuemed, serif;"]Max. torque (Nm) 135[/font]
[font="helveticaneuemed, serif;"]No load speed gear 1 (rpm) 0 - 550[/font]
[font="helveticaneuemed, serif;"]No load speed gear 2 (rpm) 0- 2000[/font]
[font="helveticaneuemed, serif;"]No. of batteries supplied 2[/font]
[font="helveticaneuemed, serif;"]Speed settings 2[/font]
[font="helveticaneuemed, serif;"]Supplied in HD Box[/font]
[font="helveticaneuemed, serif;"]Voltage (V) 18[/font]
[font="helveticaneuemed, serif;"]Weight with battery pack (kg) 2.5[/font]
[font="helveticaneuemed, serif;"]Wood screws to (mm) 10[/font]
M18 FMTIWF12 M18 FUEL™ ½˝ MID TORQUE IMPACT WRENCH WITH FRICTION RINGFEATURES
The M18 FUEL™ mid torque impact wrench delivers 610 Nm in a compact size of only 170 mm
The Milwaukee® DRIVE CONTROL™ allows the user to shift into three different speed and torque settings to maximise application versatility
Milwaukee® designed and built brushless POWERSTATE™ motor for longer motor life and more power
½˝ square friction ring
On board fuel gauge and LED light
