November Special Offer to Members - £145.00 inc vat & free delivery - SRP £190.00 inc vat
This is new to the Milwaukee range this year and is a great under bonnet LED light and with it's soft pads on each end you can also use it as a valet light spanning across the car from door to door.
The light is also adjustable as it slides up and down the rail, you can rotate to any angle and even remove it from the frame if need be. It also has 2 modes of brightness.
It runs on any M12 Milwaukee battery (not included) and these can be found cheap online or we can also supply.
If you need any further info please feel free to contact us and you can pay by PayPal, Bank Transfer or Visa Card.
We are Milwaukee distributors so we can supply anything in the range you need, please just drop us an email.
TRUEVIEW™ high definition light output delivers consistent beam, optimised colour temperature and true representation of colours and detail
Impact and chemical resistant polycarbonate lens to withstand common automotive fluids
IP54 - protected from dust and splashing water
Flexible battery system: works with all Milwaukee® M12™ batteries
Two light output settings with 1350 and 600 Lumens to maximise run time and to optimise lighting output
M12™ 4.0 Ah battery provides 4 hours of run time in high and 8 hours of run time in low setting
Mounting hooks extend 119 cm - 196 cm (47˝ - 77˝) covering wide cars and trucks
Flexible and versatile light bar to rotate vertically, adjust position and remove from the carrier to suit user needs
Rubber gripping surface for maximum hold
Milwaukee®’s FINISHGUARD™ hooks provide lasting protection against scratches to a vehicle’s finish
Stainless hook allows to hang the light bar independently from the carrier
Aircraft grade aluminium frame ensures maximum durability
