Would it be weird to get the current geo checked to know where you are?
Posted 13 November 2017 - 04:27 PM
Posted 13 November 2017 - 04:49 PM
Not at all. Being done this week
Posted 13 November 2017 - 10:19 PM
You should be able to see how many shims you have front and rear for caster.
Posted 13 November 2017 - 10:25 PM
Posted 13 November 2017 - 10:42 PM
Thanks Mark, I* will check this out. I know the wishbones have been out so will be interesting to see if they were refitted correctly. Is this the only way to adjust castor? I take it that its the number of shims front/rear that effects the adjustment? *i will get a competent person to check for meYou should be able to see how many shims you have front and rear for caster.
Posted 13 November 2017 - 10:43 PM
Yes and yesIs the car on lowered suspension? If so check the rack has the raiser plates fitted.
Edited by Foxy, 13 November 2017 - 10:45 PM.
Posted 13 November 2017 - 11:13 PM
Posted 14 November 2017 - 07:48 AM
Castor +/- shims on our cars make barely any difference, so you are barking up the wrong tree.
Posted 14 November 2017 - 09:28 AM
Drop me a call if you want. Think I did the setup on the car. Shouldn't be that, but good points made on no oe/delphi ball joints. If you use anything other than those you get heavy steering and loss of self-centering effect.
Matt
Posted 14 November 2017 - 11:26 PM
Thanks very much Matt. Will give you a bell next weekDrop me a call if you want. Think I did the setup on the car. Shouldn't be that, but good points made on no oe/delphi ball joints. If you use anything other than those you get heavy steering and loss of self-centering effect. Matt
Posted 14 November 2017 - 11:27 PM
Thanks Nev.Castor +/- shims on our cars make barely any difference, so you are barking up the wrong tree.
Posted 08 March 2018 - 11:34 AM
Update:
Sent rack to Titan - they say rack, pinion and bearings are all very worn and need replacing - full refurb cost is about £380 so not much less than a new rack
I'm inclined to go for a new rack - Titan one is over £500 but if I don't buy theirs I'll be stung for inspection costs...
What to do?
Posted 08 March 2018 - 11:52 AM
For that sort of pricing, I'd be tempted to go new - I assume the new one will come with a warranty while the refurb won't?
Posted 08 March 2018 - 11:55 AM
refurb it , and just stick £20 in a jar each month
Posted 08 March 2018 - 12:25 PM
Posted 08 March 2018 - 12:28 PM
EU 2 year warranty by law
Posted 08 March 2018 - 01:30 PM
How much is inspection costs? £380 they make it like new and send it back is the option I would go for. Must come with some form of warranty. How many miles has it done ? If you need to face this cost again
Inspection is £95
Refurb is £375
New std rack is £485
New quick rack is £530
I'm inclined to go for a new rack then flog the old one (or refurb elsewhere and flog)
Car has only done 57k ish.
Seems odd that wear is causing the rack to stiffen up - i have no play. Humm...
Edited by Foxy, 08 March 2018 - 01:34 PM.
Posted 08 March 2018 - 11:02 PM
wait till tomorrow when i can tell you how much we sell our refurbed racks for
Posted 08 March 2018 - 11:25 PM
Interesting Chris, a good quality rack would be good.
If the super heavy steering is most obvious on track could it be more likely ride height, wheel off set or geo related.
As a side note I have gone from very low ride height and 205 AD08's to Eiback lowering springs & std dampers and 195 NS-2R's and the steering has gone from torture at all speeds especially on track to light (after 40 mph). For most of the last 15 years I have been swimming half a mile a day so my arms are not too weak.
Why not give Mat a call and see if he can point you in the right direction.
Kindly, Paul
Posted 09 March 2018 - 10:03 AM
I find putting some air in the tyres helps
General Discussion →
VX220 Discussion →
Black Friday DealsStarted by Matthew Bentley Racing Ltd , 22 Nov 2018 ![]() |
VX220 Discussion →
Missing Camber ShimsStarted by Raptor , 21 Mar 2017 ![]() |
Member Product/Service Reviews →
Kenneth Brown Motor Engineering- GlasgowStarted by MJ101 , 09 Sep 2015 ![]() |
Off topic Chat →
Poll
DinnerStarted by Andrew aka Stuwy , 24 Mar 2014 ![]() |
Tuning & Modifications →
Mb Racing Damper And Setup DealStarted by Matthew Bentley Racing Ltd , 23 May 2013 ![]() |
