Hi all,
Got a Bilstein damper group buy for you, direct from Bilstein to the correct spec. NA's are easy, Turbos a slightly more tricky. Basically NA dampers I can supply off the shelf, the rear turbo damper is a different length and damping, Bilstein haven't had any for quite a while so I am having to get Bilstein to make these for us.
Price wise we are looking at:
NA full damper set (two rear and two front with spring collars) RRP £525+vat a set.
3 sets - £420+vat per set
5 sets - £395+vat per set
8 sets - £350+vat per set
Turbo full damper set (two rear and two front with spring collars)
3 sets - £585+vat per set 5 sets - £555+vat per set 8 sets - £515+vat per set
Shipping is £10+vat per set. If anyone is interested then I will start a list.
Thanks
Matt
