P0141 - O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2) (00) -
Posted 07 January 2018 - 03:08 PM
Posted 07 January 2018 - 03:26 PM
Probably a broken wire = new sensor. Does anyone know if there is a cheater available, seem to remember there was talk of one.
Posted 07 January 2018 - 03:28 PM
on the lambda plug , check the voltage on the #RED-WHITE wire
Posted 08 January 2018 - 10:24 AM
I've still got a load of PCB's for the cheater I made, and a few resistors riveted to Ali heat sinks etc.
I dont have the time to do much with it though
Posted 08 January 2018 - 10:52 AM
Had this on my old MR2, made no difference to the running of the car, I bought a new sensor but you can wire in a cheater I think.
Posted 08 January 2018 - 03:38 PM
[font="arial, helvetica, sans-serif;"][color=rgb(0,0,0);]Hi,[/color][/font]
[font="arial, helvetica, sans-serif;"][color=rgb(0,0,0);]I have actually the same error-problem but it was only after changing to a new cloned ECU with obd-tuner.[/color][/font]
[font="arial, helvetica, sans-serif;"][color=rgb(0,0,0);]After changing the second lambda through a new one the error still reappear.[/color][/font]
Think the error comes in the warming up phase. Also SC stage 2, no pre cat and 200 cpi sportscat.
Do you have also the obd-tuner Software?
Posted 08 January 2018 - 05:41 PM
This is interesting as I recently switched to a new ECU with OBD Tuner when I had the SC conversion done. The error appeared around 500 miles after moving to the dutch software so I cant say for sure if it is a result of that or a faulty sensor. My setup is identical to yours though which ties in.
Have you contacted Peter yet regarding this?
Posted 08 January 2018 - 05:56 PM
Yes. And I send him a log file. The sensor is o.K. and I should delete the error again. Than I will create a new log direct after cold start.
So in the moment no idea.
Posted 08 January 2018 - 06:03 PM
Posted 08 January 2018 - 06:19 PM
Ok great , please keep this thread updated with your findings if you can please.
I am going to try and test the sensor at the weekend.
Posted 10 January 2018 - 05:13 PM
Today and yesterday I am driving over 1h through the area and… no pid-error. Also obd-tuner says now that the lambda-test is O.K.
So I think the problem was the second lambda. Before I changed the lamda I start the engine to jack up the speedy and I don’t check the errors again before I test the new one.
Posted 10 January 2018 - 11:21 PM
