Vx220 N/a Misfire? Help!
vx220 misfire na 2.2 help
19 replies to this topic
#1 MattMacc123
MattMacc123
  • 118 posts
  • Interests:Cars, Music, Guitars, fitness, Mechatronics and Robotics
Posted 12 January 2018 - 11:22 AM
Hi All,
I have parked the car up for the winter, but before i did this, i was noticing an intermittent Misfire when accelerating.
I had the car serviced a year ago at Murray Lotus in Edinburgh who replaced my spark plugs. I am just wondering, do you think there could be water on the spark plugs causing this misfire? or could it be the coil pack? I'm not massively mechanical minded when it comes to cars. So this is where I am hoping to learn.
Another thing I am worried about is that i am not getting full performance due to this issue? or is this just me getting used to the car?
Any help would be appreciated.
Thanks!
Edited by MattMacc123, 12 January 2018 - 11:25 AM.
#2 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 12 January 2018 - 11:26 AM
Coil pack or water in the plug holes.
Take the coil out 4 10mm bolts and unplug the connector and look in the holes, any water theres your issue.
#3 james_ly
james_ly
  • 864 posts
Posted 12 January 2018 - 11:29 AM
I find if I don't drive the car for a couple of weeks it has a misfire for the first couple of miles, I've always assumed it's water on the coil. Have you tried an Italian tune up ;)
#4 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 12 January 2018 - 11:40 AM
Sounds like you need new spark plugs.
#5 MattMacc123
MattMacc123
  • 118 posts
Posted 12 January 2018 - 11:49 AM
Brilliant thanks for this guys, If there is water getting into the coil pack? what could be the reason for this?
#6 CHILL Gone DUTCH
Posted 12 January 2018 - 12:03 PM
Maybe the plugs are operating out of range in the cold weather
#7 MattMacc123
MattMacc123
  • 118 posts
Posted 12 January 2018 - 12:13 PM
I will have a little browse when i am back at the weekend and give the car a little once over. Thanks again!
#8 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 12 January 2018 - 12:23 PM
We've not had a cracked head from an overtightened spark plug for a while. Just be aware that that is common on these engines.
#9 MattMacc123
MattMacc123
  • 118 posts
Posted 12 January 2018 - 12:27 PM
Thanks for this tip as well! il be careful not to tighten too much
#10 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 12 January 2018 - 12:49 PM
 you bought a VX220 !  :gayfight:  the water works its way in on a wet day through the boot grilles and runs into the engine bay and ultimately into the holes.
#11 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 12 January 2018 - 12:51 PM
25nm for the plugs no more !
#12 MattMacc123
MattMacc123
  • 118 posts
Posted 12 January 2018 - 12:52 PM
Of course! ha Makes sense really! hm so just dry the coil pack out if this is the reason and all should be good?
#13 g1977
g1977
  • 344 posts
Posted 12 January 2018 - 02:34 PM
I had this on my car, checked all the coil pack etc, in the end it was a hairline crack in the spark plug and they had recently been changed. Whip them all out and check them carefully. I made sure I tightened them back with a torque wrench.
Good luck.
#14 MattMacc123
MattMacc123
  • 118 posts
Posted 12 January 2018 - 02:44 PM
Good luck.
a hairline crack on the spark plug its self? or the head? :) thanks!
#15 g1977
g1977
  • 344 posts
Posted 12 January 2018 - 02:47 PM
On the spark plug itself.Not the head - thankfully.
#16 MattMacc123
MattMacc123
  • 118 posts
Posted 12 January 2018 - 02:57 PM
Ah excellent, Thanks for this! il have a check at the weekend :)
#17 Rosssco
Rosssco
  • 4,183 posts
Posted 12 January 2018 - 03:40 PM
Good luck.
Probably just water in the plug from sitting outside. Cyl.1 tends to get it the worst..
If it does end up as the cylinder head (here's hoping not) I have a cheap, low mileage cyl. head available (just needs cams)
#18 smiley
Posted 12 January 2018 - 10:31 PM
The turbo had the same problem and they designed a deflector for that. https://www.regelin-...over-turbo.html It can be altered to fit the NA iirc.
#19 Rosssco
Rosssco
  • 4,183 posts
Posted 13 January 2018 - 10:56 AM
Any info on that mod Smiley?
#20 g1977
g1977
  • 344 posts
Posted 16 January 2018 - 04:29 PM
This was the plug on mine not water.
Good luck.
Also tagged with one or more of these keywords: vx220, misfire, na, 2.2, help
