2Nd Time Round! - Twincharge
433 replies to this topic
#401 1cobrav8
1cobrav8
    Joe is faster than me
  • 516 posts
Posted 24 January 2019 - 06:10 PM
is that some pitting on the crank surfaces?
Its just really light surface rust, will all come of when the crank journals get polished the same time as the assembly is balanced
#402 Arno
Arno
  • 1,238 posts
Posted 25 January 2019 - 07:31 AM
Valve spring kit .......although the Ti retainers are missing  :angry2:
Do keep an eye on these when the engine has been running a while.
Seen a few engines with Ti retainers where they started galling/fretting between the spring and the retainer and sometimes on the keepers too causing them to wear down and thin out in areas.
No clue why it happens sometimes (probably some resonance thing) but it's usually fairly easy to spot if you take some photos of the 'fresh install' and then check them after a few thousand miles. If they show no signs of wear by that time you should be fine indefinitely.
#403 ayresyy
ayresyy
  • 489 posts
Posted 25 January 2019 - 07:38 AM
8” GARW dash fitted tonight along with the additional finishing supports to the sideskirts. Apart from putting some base settings in the dash I think we’re ready for cadwell :)
    I would be interested to see how you fitted the 8" Garw, I offered mine up then it ended up back in the box due too a serious lack of ideas!
Edited by ayresyy, 25 January 2019 - 07:40 AM.
#404 vocky
Posted 25 January 2019 - 09:23 AM
you only get them with double valve spring kits, use OEM retainers with single valve springs
#405 1cobrav8
1cobrav8
  • 516 posts
Posted 25 January 2019 - 10:18 AM
I've not gone for the supertech springs this time Vocky as i've heard of some failures. I'm trying the OTTP 80lbs spring kit which does come with Ti retainers. They were just missed out of the box. They've now been shipped and should be with me monday at the latest.
#406 1cobrav8
1cobrav8
  • 516 posts
Posted 25 January 2019 - 10:20 AM
Hi Arno,
Yes we see this quite often in our Hayabusa engines as well which run the titanium retainers in tuned applications. We normally get two seasons out of them before replacing them. Ideally I will run the 2.5 for this season and then pull it out over the winter to rebuild and inspect it.
#407 chris_uk
Posted 25 January 2019 - 04:01 PM
Thats what happened with my supertech valves...
#408 1cobrav8
1cobrav8
  • 516 posts
Posted 26 January 2019 - 09:20 PM
Head removed from the new B207 today. Will get it stripped and sent off for porting and oversized valves next week ....
Valves require a of deshrouding and the exhaust ports are very small
#409 CHILL Gone DUTCH
Posted 27 January 2019 - 10:07 AM
take a pic of the block without the gasket on
please
Edited by CHILL Gone DUTCH, 27 January 2019 - 10:13 AM.
#410 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 27 January 2019 - 10:09 AM
Please.
#411 CHILL Gone DUTCH
Posted 27 January 2019 - 10:14 AM
edited
#412 1cobrav8
1cobrav8
  • 516 posts
Posted 27 January 2019 - 10:37 AM
please
Typical I read this once I’ve left! Just been in to strip the head ready to go away and collect that splitter for you. Will get you s picture next week.
#413 FLD
Posted 28 January 2019 - 09:18 AM
Bigger valves going in?
#414 1cobrav8
1cobrav8
  • 516 posts
Posted 28 January 2019 - 12:35 PM
+1mm ferrea valves 👍🏼
#415 Peter VXR29
Peter VXR29
  • 811 posts
  • Interests:Bike and car track days
Posted 28 January 2019 - 07:52 PM
Sent you a pm
#416 1cobrav8
1cobrav8
  • 516 posts
Posted 07 February 2019 - 05:43 PM
Rods arrived today for the 2.5....
So the A beams went back as I order them by mistake. The new ‘unbreakable’ H-beams fitted with carrillos top spec bolts have arrived....
#417 Talk-torque
Talk-torque
  • 150 posts
Posted 07 February 2019 - 07:01 PM
Component porn! Beautiful thing - shame to hide them inside an engine.
Edited by Talk-torque, 07 February 2019 - 07:02 PM.
#418 italikko
italikko
  • 50 posts
Posted 15 February 2019 - 12:10 PM
May i ask where could i find this difuser?
#419 1cobrav8
1cobrav8
  • 516 posts
Posted 23 February 2019 - 11:48 PM
Downgrading for a little while whilst the 2.5 is built....
#420 The Batman
Posted 24 February 2019 - 12:01 AM
:wub: so shiny
