2Nd Time Round! - Twincharge
#141
Posted 25 May 2018 - 02:18 PM
#142
Posted 02 June 2018 - 07:16 PM
#144
Posted 03 June 2018 - 12:30 PM
#145
Posted 03 June 2018 - 01:55 PM
#146
Posted 04 June 2018 - 05:53 PM
Looks like it's been washed
shit parking tho
#147
Posted 05 June 2018 - 07:30 PM
Edited by 1cobrav8, 05 June 2018 - 07:31 PM.
#148
Posted 28 June 2018 - 06:31 PM
So the cars back in peices again for several upgrades and checks....
New custom exhaust system
New breather system
M8 conversion the the inlet manifold bolts on the head
Strip inlet to clean it along with laminovas
Change water injection jet sizes, currently 0.5. Now changing to 0.7
Fit 6 rib alt pulley and belt
Remove all the carbage from the right hand side of the engine bay
Cut outs to the rear clam
Carry out rear clam hinge conversion
Make and fit large front splitter
Make a pair of new fuel pipes as per my last car
Heat proof/reflective tape around the tailpipe to protect the clam
#149
Posted 28 June 2018 - 06:58 PM
#150
Posted 28 June 2018 - 06:59 PM
I suggest you put that heat shield back on which sits between the clam and subframe.
There will be no clam to shield so it’s staying in the bin lol
#151
Posted 28 June 2018 - 07:15 PM
those cut outs are bloody b e a utiful
#152
Posted 29 June 2018 - 01:20 AM
The rear cut outs look good, are they to improve airflow out of engine bay to help engine & gearbox temps? Do you have to put some braces in to strengthen this area?
Is the reflective tape to put on the body work by the tips? As mine got burnt at my track day.
Can you tell me what are those 4 cylinders? In your pic?
Sent from my LG-H815 using Tapatalk
#153
Posted 29 June 2018 - 07:34 AM
Another Nutter! This site so needs people like this!
...Good to see it's not just being used just as a drag queen for road use!
#154
Posted 29 June 2018 - 07:50 AM
Hi,
Cuts out are for both looks and improved airflow/cooling, this will only be so effective on mine due to the fact I am also cutting out all of my boot so the air can flow in and out with ease.
Yes the reflective tape will be put around the exhaust tips, my new exhaust will only have a single 3" exit pipe as apposed to the current twin 3.5" setup. This should also help as it will no longer be so close to the clam.
The four cylinders are the laminovas that have been removed from the inlet manifold for cleaning. These probably haven't been cleaned in 4-5 years so were seriously over due. If you have oil or debris around the laminovas it causes both poor flow and poor cooling of the inlet temps.
#155
Posted 29 June 2018 - 07:52 AM
No fun just being the same as everyone else max lol. The car is a long way of from where it needs to be but i'm hoping this latest batch of mods will allow the car to remain in one piece hopefully until the end of the year now.
#156
Posted 29 June 2018 - 01:23 PM
How much power does it run now to max out the 2x 0.5mm WI jets, as those should be enough for ~400hp?
(And how is that Piper 2.5 manifold holding up with all the heat? These tend to crack very easily with some SC power...)
#157
Posted 29 June 2018 - 02:19 PM
#158
Posted 29 June 2018 - 04:29 PM
Power is pretty poor atm Frank, which is why it’s all apart again. The inlet temps were high on track considering I had water/meth running....50deg average. Though I now suspect that was down to all the oil in the inlet manifold blacking the laminovas. I’ve increased the jets just to give me plenty of scope when mapping as it’s all controllable through the obd pro software.
Power run after the national showed the engine was only running at 300bhp....rubbish lol!!!
#159
Posted 29 June 2018 - 04:36 PM
#160
Posted 29 June 2018 - 04:55 PM
Was that on your dyno or in the software? Remember that the software doesnt take into consideration any aero drag on the car.
That was on my dyno Chris
