2Nd Time Round! - Twincharge
433 replies to this topic
#161 1cobrav8
1cobrav8
    Joe is faster than me
  • 516 posts
Posted 29 June 2018 - 05:00 PM
On of the runs from my old Vx vs my current one 😭👎🏻
#162 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 29 June 2018 - 06:53 PM
Would be interesting to see what power the software tells you vs what it actually is on a dyno.
#163 1cobrav8
1cobrav8
  • 516 posts
Posted 29 June 2018 - 08:25 PM
I did that on my last one, safe to say the software is pretty accurate.
#164 1cobrav8
1cobrav8
  • 516 posts
Posted 07 July 2018 - 10:52 PM
Spent a few more hrs on the car this week. Managed to get most of the engine bay back together, just a few small jobs left mounting the relays and refitting the air filter etc. Also had Joe come over and lend a hand today to get the rear clam hinge system working. Really pleased with how it’s turning out tbh. Just waiting for some push fit fasteners so I can mount the rear coupe to the clam now so it hinges with it.
Then I need to mount the new rear diffuser and wheel arches etc. Car goes for the new exhaust on Tuesday so I’m hoping it will be back on the road soon.
Edited by 1cobrav8, 07 July 2018 - 10:55 PM.
#165 swast4
swast4
  • 416 posts
  • Interests:Trackdays
Posted 07 July 2018 - 11:14 PM
Looking good, will you be able to lift it up with the diffuser fitted?
Sent from my LG-H815 using Tapatalk
#166 1cobrav8
1cobrav8
  • 516 posts
Posted 07 July 2018 - 11:17 PM
New rear diffuser is going on which will have two quick release pins to allow the rear to drop, this will give room for the clam to flip
Edited by 1cobrav8, 07 July 2018 - 11:34 PM.
#167 swast4
swast4
  • 416 posts
Posted 07 July 2018 - 11:23 PM
That makes sense
#168 1cobrav8
1cobrav8
  • 516 posts
Posted 10 July 2018 - 07:44 PM
Exhaust almost finished....
#169 swast4
swast4
  • 416 posts
Posted 10 July 2018 - 07:58 PM
Wow, that's a beast.
I've just been to Oulton today, and did 99db at 4. 5k and had no black flags all day! So fingers crossed I've eventually got there
#170 1cobrav8
1cobrav8
  • 516 posts
Posted 10 July 2018 - 09:11 PM
How did you cure it mate?
#171 Exmantaa
Posted 10 July 2018 - 10:36 PM
Impressive girth... :happy:
What size primary/secondary you used?
#172 1cobrav8
1cobrav8
  • 516 posts
Posted 11 July 2018 - 05:33 AM
2” primaries, 2.5” secondaries and 3” final frank
#173 swast4
swast4
  • 416 posts
Posted 11 July 2018 - 06:45 AM
I put 2 extra Repackable silencers in, 1 (12"x5") where the cat was and another (11"x5") after the main silencer and tail pipe. Then put a single 3" tip on the back, then a removable 90 degree tip pointed away from the noise meters.
Originally when I repacked the main silencer (which didn't need doing) one of the nuts came off the inside and I used a rivet to fill the hole, this was too small and fragile and blew out causing packing to blow out in the localised area. Which happened to be where there was only 1cm between perf pipe and silencer wall.
Another thing the exhaust guys said I could do is put a empty chamber in the main box (this is what tubular doo).
#174 1cobrav8
1cobrav8
  • 516 posts
Posted 11 July 2018 - 09:48 PM
Out of pure curiosity are you having any breathing/oil issue with yours on track? It’s been a big debate with a few of us but I’m now going back to what I did on your car as what I tried on my current car didn’t work at all.
#175 swast4
swast4
  • 416 posts
Posted 12 July 2018 - 07:17 AM
In regards to what issues? It's got a large open oil breather pipe going from top of engine and pokes just under the tray.
I'm not getting any funky smells or oil visable from the pipe. I had to put about 1 litre of oil in across the day and that's when it was a scorching day and driven hard.
#176 Nev
Posted 13 July 2018 - 04:58 PM
Direct 1" pipe from the crankcase vertically upward, big swirl pot with brillo pads in it and then a 1" pipe down to the floor on mine - it worked an absolute treat. Some pics + write up on my thread.
Edited by Nev, 13 July 2018 - 05:00 PM.
#177 1cobrav8
1cobrav8
  • 516 posts
Posted 18 July 2018 - 08:22 AM
New diffuser under way, dropped it off to be finalised after a few clearance mods carried out last night
#178 1cobrav8
1cobrav8
  • 516 posts
Posted 23 July 2018 - 08:37 PM
Diffuser now fully mounted and the clam still flips fine which is a bonus! Some very small alterations to make before painting it but that can wait until it’s been road tested!
Edited by 1cobrav8, 23 July 2018 - 08:38 PM.
#179 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 23 July 2018 - 09:02 PM
you have any clear pics of the hinge mechanism? or even better a diagram with dimensions/Pivot Locations?? am looking at doing exactly this shortly :)
#180 swast4
swast4
  • 416 posts
Posted 24 July 2018 - 05:45 AM
Looks ace and would be great great to work on.
How's the exhaust sounding?
8 user(s) are reading this topic
    Bing (4)
