Opel Speedster 2,2 Nr 1047 B207 Td04-20T Turbo
60 replies to this topic
#41 piwo
piwo
  • 174 posts
Posted 25 April 2020 - 03:54 PM
#42 piwo
piwo
  • 174 posts
Posted 23 May 2020 - 06:22 PM
Ok I had to replace the glass (150 pounds)
I also replaced my bilstein b16 lotus cup suspension at the back and bilstein b6 at the front for nitron suspension and I have a problem with heights at the front and rear. the floor is at the back at a height of 11.5cm and at the front at 10.5cm and with quite a large spring pre load. the fact that I have 215 / 40r17 tires (60cm diameter) instead of 62.5cm but I did not think that the car sits so hard.
#43 2-20
2-20
  • 1,317 posts
Posted 24 May 2020 - 08:40 PM
What's your nitrons extended lengths ??
Do you know that the first Nitrons sold for the VX were too short...
#44 piwo
piwo
  • 174 posts
Posted 28 May 2020 - 05:36 PM
New geo
#45 piwo
piwo
  • 174 posts
Posted 27 July 2020 - 05:13 PM
My new very very soft front tires
#46 2-20
2-20
  • 1,317 posts
Posted 27 July 2020 - 05:28 PM
Very high camber figures.
Never seen anyone going so high...
Or may be I didn't find the right figures.
How much camber exactly ???
Edited by 2-20, 27 July 2020 - 05:30 PM.
#47 piwo
piwo
  • 174 posts
Posted 27 July 2020 - 05:43 PM
-3°30' rear And -3°40' front. 10,5cm high front and 11,5cm rear. I'm testing this geo.
I am very pleased with that. times have improved and the outer parts of the tires are not cutting.understeer has also disappeared.
Edited by piwo, 27 July 2020 - 05:43 PM.
#48 2-20
2-20
  • 1,317 posts
Posted 27 July 2020 - 06:16 PM
Ok... with 17 inch wheel you are driving on bumpstops
#49 piwo
piwo
  • 174 posts
Posted 27 July 2020 - 06:28 PM
No. I have the shock absorbers positioned equally in the middle of the stroke under the weight of myself and the car
#50 2-20
2-20
  • 1,317 posts
Posted 27 July 2020 - 07:11 PM
Oh yes... you have the short Nitrons.
Then check that your rear wishbones are not touching the sub frame at full compression.
#51 TFD
TFD
  • 607 posts
Posted 28 July 2020 - 03:46 PM
What turbo at what boostlevel?
#52 piwo
piwo
  • 174 posts
Posted 28 July 2020 - 04:20 PM
Td04-20t. 1 bar ascending to 1,2 bar.
#53 TFD
TFD
  • 607 posts
Posted 01 August 2020 - 07:33 AM
Ascending boost? Is that a boost control issue or on purpose? Explains the nice flat torque curve.
I want that curve!
#54 TFD
TFD
  • 607 posts
Posted 01 August 2020 - 07:35 AM
Oh wait... torque axis is different. My bad.
#55 piwo
piwo
  • 174 posts
Posted 01 August 2020 - 04:03 PM
I didn't want to exceed 400Nm and I want high power at the same time.the power is a bit higher because on the dynamometer I had damaged two ignition coils
Edited by piwo, 01 August 2020 - 04:05 PM.
#56 Jocke_D
Jocke_D
  • 407 posts
Posted 20 August 2020 - 12:38 PM
Where to buy a new windshield?? :)
Edited by Jocke_D, 20 August 2020 - 12:39 PM.
#57 piwo
piwo
  • 174 posts
Posted 20 August 2020 - 03:44 PM
https://szyby24.pl/p...0010190836.html
#58 alanoo
alanoo
  • 1,324 posts
Posted 22 August 2020 - 10:53 AM
Wow nice price as I need a new one too.
Just wondering, on your pics... Is it your used windshield cleanly removed ? So it's possible to remove an existing one non destructive ? I have a good one on a spare chassis to if it's doable it would be great in fact.
#59 piwo
piwo
  • 174 posts
Posted 22 August 2020 - 02:55 PM
Yes used. It's no problem.
#60 piwo
piwo
  • 174 posts
Posted 28 May 2024 - 05:28 PM
