#21
Posted 24 February 2018 - 09:46 PM
#22
Posted 24 February 2018 - 09:51 PM
#23
Posted 25 February 2018 - 11:06 AM
Try disconnecting the sensors one at a time and clearing the errors. Sent from my SM-G903F using Tapatalk
Don't really understand what you mean .... disconnect the sensor clear the fault and plug it back in?
#24
Posted 25 February 2018 - 11:17 AM
#25
Posted 25 February 2018 - 06:50 PM
Do you have a voltage at the coolant temperature sensor plug ? Looks like you have lost a feed somewhere. Sent from my SM-G903F using Tapatalk
Yes tested today , It has two life , is it suppose to have !
#26
Posted 25 February 2018 - 07:06 PM
#27
Posted 25 February 2018 - 07:10 PM
I've deleted all fault codes , but once engine running they are all comeback .
No eml light on the dash .
List of fault codes:
P0115 coolant temperature sensor
P1105 Atmoshperic pressure sensor malfunction
P1106 Turbocharger wastegate solenoid A malfunction
P0135 O2 sensor heater circuit ( bank 1 , sensor 1 ) CHECKED PLUG CONNECTION , SENSOR LIKE NEW .
P0340 camshaft position sensor . SWAPPED IT TODAY
P0100 mass or volume air flow circuit . IT COULD RUN WITHOUT SENSOR ON BASE MAP , SO WONT BE THAT WHAT CAUSE MAYHEM .
#28
Posted 25 February 2018 - 07:11 PM
#29
Posted 25 February 2018 - 07:12 PM
Unplug it and test the live - what voltage is it ? Sent from my SM-G903F using Tapatalk
I home now do it tomorrow , what voltage should be ?
#30
Posted 25 February 2018 - 07:16 PM
Fuel pump priming , throttle buzzing , it starts and runs quite steady on idle , but then fade away and starts misfire and eventually stalls
#31
Posted 25 February 2018 - 07:18 PM
#32
sounds like a earthing fault to me, but a starter motor can cause all types of electrical issues
#33
Posted 25 February 2018 - 07:21 PM
#34
Posted 25 February 2018 - 07:23 PM
#35
Posted 25 February 2018 - 07:24 PM
#36
Posted 25 February 2018 - 07:28 PM
Manchester
#37
Posted 25 February 2018 - 07:33 PM
Where are you Egor ? Sent from my SM-G903F using Tapatalk
If you have a second to come down at some point I will pay for your expenses and labour , whatever you find something or not !
#38
Posted 25 February 2018 - 07:34 PM
Meanwhile I will check the voltage and the other bits...
#39
Posted 25 February 2018 - 07:38 PM
Car on axle stands , rear clam off ...
#40
Posted 25 February 2018 - 08:08 PM
Also tagged with one or more of these keywords: eeprom error, wiring
General Discussion →
VX220 Discussion →
Hid Fog Lamp Mod > Switches & Wiring Advice Req.Started by Benzola , 18 Sep 2016 ![]() |
VX220 Discussion →
Indicator FailureStarted by Bandris11 , 24 Sep 2014 ![]() |
Tuning & Modifications →
14V Hardwire For In Car CctvStarted by Benzola , 06 Mar 2013 ![]() |
Fan Switch Wiring...Started by Dunk , 03 Feb 2013 ![]() |
