#41
Posted 25 February 2018 - 08:20 PM
#42
Posted 26 February 2018 - 08:25 PM
Reading from lambda pin 1-12.30 volts
pin 2-3.60 volts
reading from t/sensor pin1-12.30 volts
pin2- 5.03 volts
tomorrow going to try running the car and disconnect the one by one and clear the faults after each disconnected , like Johnboyhgt advised .
What can I try regarding earth ( ground) , check continuity , resistance on wires itself ?
#43
Posted 26 February 2018 - 08:31 PM
Edited by CHILL Gone DUTCH, 26 February 2018 - 08:32 PM.
#44
Posted 26 February 2018 - 08:44 PM
Another thought. Plug in your original ecu and key reader. Tape one of the chips to the key reader. Try start it up. I suspect you will get all the same codes up. Sent from my SM-G903F using Tapatalk
A short story about my original Ecu .
I've had a problem with the car , it would not accelerate past 4000 rpm sound like run out of petrol , but when disconnect air flow meter it would run perfect .
Someone looked at lambda wiring and said the pins on the sensor in the wrong way , so I swopped them , it would make no difference , in fact it was worse , so I left the it , car was parked up for a couple of months , when I decided to move it was not able to start .
Next I found there loads of oil in the inlet manifold , so did the compression test , cylinder n1 down to 50 psi , so bought new engine , and when fit it car has no sighs of fuel pump priming or throttle body buzzing , also could not to enter for a diagnostic too.
#45
Posted 26 February 2018 - 08:48 PM
Put a jump lead from negative on battery to the block/gearbox and then link to the ecu housing
Do I use terminal that in the left sill on the chassis ?
Thanks
#46
Posted 26 February 2018 - 08:50 PM
#47
Posted 26 February 2018 - 08:53 PM
I will try this tomorrow .
Thank you
#48
Posted 27 February 2018 - 04:43 PM
Bad MAF sensor????
No MAF= runs good
With MAF= runs bad
= bad MAF
code P0100?
#49
Posted 27 February 2018 - 08:44 PM
Bad MAF sensor????
No MAF= runs good
With MAF= runs bad
= bad MAF
code P0100?
MAF was replaced , no difference .
#50
Posted 27 February 2018 - 08:48 PM
#51
Posted 27 February 2018 - 08:59 PM
Now looking for someone to recover vx from Manchester to York 80 MILES , no tow eye , car very low 100 , needs fully dismantle bed .
Thanks in advance.
#52
Posted 27 February 2018 - 09:03 PM
Tibby is trying to say perhaps your replacement was faulty. Sometimes the aftermarket ones are poor quality. Sent from my SM-G903F using Tapatalk
are you collecting vx cars which need work doing to them
#53
Posted 27 February 2018 - 09:04 PM
Yes , that is right some aftermarket staff already faulty , but you know about car a bit and its not that .
Was trying to crank it today , would not even do anything at all ...
#54
Posted 27 February 2018 - 09:06 PM
Sounds like timing out , but timing is fine..
#55
Posted 27 February 2018 - 09:10 PM
#56
Posted 01 March 2018 - 02:05 PM
#57
Posted 01 March 2018 - 07:59 PM
#58
Posted 01 March 2018 - 08:01 PM
#59
Posted 02 March 2018 - 12:58 PM
Try bypassing the fuel cut off switch. Bolted to the subframe left side. Sent from my SM-G903F using Tapatalk
#60
Posted 02 March 2018 - 01:24 PM
Also tagged with one or more of these keywords: eeprom error, wiring
General Discussion →
VX220 Discussion →
Hid Fog Lamp Mod > Switches & Wiring Advice Req.Started by Benzola , 18 Sep 2016 ![]() |
VX220 Discussion →
Indicator FailureStarted by Bandris11 , 24 Sep 2014 ![]() |
Tuning & Modifications →
14V Hardwire For In Car CctvStarted by Benzola , 06 Mar 2013 ![]() |
Fan Switch Wiring...Started by Dunk , 03 Feb 2013 ![]() |
