#61
Posted 02 March 2018 - 02:17 PM
#62
Posted 02 March 2018 - 02:37 PM
connect K18 relay pin 3 ( ie. the switched output ) RED BLUE wire , and connect it to the K16 pin 3 switched input, *thick 2mm** WHITE VIOLET wire , not the thinner wire of same colour on same relay
you might get simpler results connecting RED BLUE to the switched output on K16 BROWN GREY if you suspect the relay K16 operation
this will provide 12 volts to the fuel pump and fuel injectors , ** but this is not a permanent solution **
#63
Posted 02 March 2018 - 05:39 PM
#64
Posted 03 March 2018 - 06:56 PM
#65
Posted 03 March 2018 - 07:05 PM
#66
Posted 05 March 2018 - 07:45 PM
Fuel pump relay was playing up , and ecu had a bad ground , car starts and run now , but rough .
Going to fit my old ecu kit , and see how its run then .
#67
Posted 05 March 2018 - 08:42 PM
#68
Posted 06 March 2018 - 09:10 PM
Also tagged with one or more of these keywords: eeprom error, wiring
General Discussion →
VX220 Discussion →
Hid Fog Lamp Mod > Switches & Wiring Advice Req.Started by Benzola , 18 Sep 2016 ![]() |
VX220 Discussion →
Indicator FailureStarted by Bandris11 , 24 Sep 2014 ![]() |
Tuning & Modifications →
14V Hardwire For In Car CctvStarted by Benzola , 06 Mar 2013 ![]() |
Fan Switch Wiring...Started by Dunk , 03 Feb 2013 ![]() |
