With everything stripped down, I'm wondering what colour to go for. Brake calipers have had a yellow coat so I'm thinking of going down the same route or the wishbones and hubs.
Saving My Vx From 6 1/2 Years Of Daily Driving
#61
Posted 23 April 2018 - 11:39 AM
#62
Posted 25 April 2018 - 11:49 AM
Out with the old.
#63
Posted 16 May 2018 - 12:32 PM
Hoping to have the sub frame off this evening so was just reading through the TIS. https://www.speedste...all (Z22SE).pdf On page 17: Left engine damping block (2), 1 nut 45 Nm.
Left bracket (3) –3 screws45 Nm, 1 nut.
Right engine damping block (5), –1 nut 45 Nm.
Right bracket (4) –3 screws85 Nm, 1 nut.
Air filter bracket (1) – 2 screws, 1 nut.
Is the 85 Nm correct? Seems a bit of a jump from the other side.
#64
Posted 16 May 2018 - 04:09 PM
I believe it is referring to the three M8 bolts holding the gearbox bracket to the top of the gearbox (LEFT) and the three M12 bolts holding the engine bracket to the engine (RIGHT), so yes thats correct.
#65
Posted 17 May 2018 - 06:40 AM
Noooo!With everything stripped down, I'm wondering what colour to go for. Brake calipers have had a yellow coat so I'm thinking of going down the same route or the wishbones and hubs.
#66
Posted 17 May 2018 - 08:16 AM
Wishbones powder coated yellow with hubs and steering arms black. Should have them back tomorrow.
Cheers Vocky, found a thread where someone left the side mount brackets on and lifted the engine one side at a time to free the mounts. so went with that.
Sub frame removed and it uncovered what could be the worst corrosion yet...
#67
Posted 17 May 2018 - 10:51 AM
oh boy
#68
Posted 17 May 2018 - 02:36 PM
Question for anyone in the know on exhausts. The U bend on my Milltek is pretty knackered, are these common across smaller systems? So will number 2 fit to a milltek box? https://www.deroure....&SMO=0&ST=&SC=0
#69
Posted 17 May 2018 - 03:55 PM
the NA Milltek U bend is basically identical to the standard U bend
However the Europa version is the larger Turbo version
#70
Posted 18 May 2018 - 07:33 AM
I discover your thread on z22se about the Miltek U bend looking very small in diameter actually. Is 2.5" standard then or is the Tullet downpipe I've got going to be a bit big for the Miltek back box?
#71
Posted 18 May 2018 - 07:38 AM
standard and milltek are sub 2"
The connecting flanges are the same, so the Tullet will mate up to the standard U bend
#72
Posted 18 May 2018 - 07:56 AM
The Tullett ubend is a few degrees off compare to oem, complicating the mate up.
Left Tullett, right oem.
I had a look at the NA, turbo, miltek and janspeed ubend. They are all like the right one. Just the tullett is a bit off.
#73
Posted 18 May 2018 - 08:20 AM
Damn, that's quite a drop in diameter, at least I haven't got much power to lose. So what's the best way to source a replacement? I guess just a wanted thread but can't see anyone willing to sell one without the backbox.
#74
Posted 18 May 2018 - 09:45 AM
#75
Posted 18 May 2018 - 09:54 AM
Could be cheers, but I guess that's too big to clamp to an N/A Miltek back box?
#76
Posted 19 May 2018 - 09:06 AM
#77
Posted 19 May 2018 - 10:29 AM
good power gains to be made by improving the U bend flow
#78
Posted 22 May 2018 - 11:23 AM
I guess the opposite to what I said is that I don't have much power to begin with, can't afford to strangle it more. Getting closer to reassembly now so want to be in a position to go ahead, where should I be putting thread lock?
Bearing bolts? Hub Carrier bolts? Sub Frame bolts?
And grease, everywhere except on threads? Duralac, the new sub frame shims, front suspension mounts and the undertray fixings.... anywhere else that is ally to steel?
#79
Posted 22 May 2018 - 11:28 AM
Because everyone loves pictures, even ones off of my truly awful phone. But it gives you an idea of the wishbone colour. Unfortunately, very different to the yellow the brakes came out.
Edited by VX Boyd, 22 May 2018 - 11:28 AM.
