Hid Lights
mot fail?
28 replies to this topic
#1 Gadget2
Gadget2
  • 223 posts
  • Interests:Race & Sprint Marshall
Posted 05 March 2018 - 05:18 PM
I hope I'm wrong but I've read that new MoT regs coming in May has HID lamps that have been retro fitted will result in a fail even if the pattern is correct.
Since my VX is fitted with HID main beam, and is absolutely useless with the standard halogen this means either I fit halogen just to pass the test and refit my HID's (will this make me illegal?) afterwards, or just not go out at night.
#2 Tareim
Tareim
  • 80 posts
Posted 05 March 2018 - 06:41 PM
it's going to be a tough one, some will fail it on that you have retro fitted bulbs where halogens once were, others will pass it as it will come down as interpretation of the wording, as our cars have projector units they should in theory be ok as they don't scatter the light everywhere like the old style halogen reflector lenses
#3 gaffer1986
gaffer1986
  • 4,408 posts
Posted 05 March 2018 - 08:27 PM
I find my uprated standard bulbs work better than the HIDs.
#4 Di3sel
Di3sel
  • 125 posts
Posted 05 March 2018 - 08:43 PM
Apologies for the off-topic, but which bulbs are you using?
Cheers.
#5 gaffer1986
gaffer1986
  • 4,408 posts
Posted 05 March 2018 - 08:48 PM
I can't remember. :D The bulbs that got the best results on auto express.
#6 H1 HWK
H1 HWK
  • 1,009 posts
Posted 05 March 2018 - 09:00 PM
I tried Osram night breakers (which are supposed to be good for halogens), but they wer no where near as good as HIDs for me. I only use them on low beam. Have some shitty Chinese leds I tried last year for main beams but they will be replaced with halogens before the car goes back on the road. Will be MOTing next month....can anyone confirm if the new rules come in from May as my normal place is happy with the HIDs, but dont want to put them in a position to have to fail it because of new rules in place, Thanks
#7 Strugs
Strugs
    World's #1 cheese fan
  • 3,008 posts
Posted 05 March 2018 - 10:11 PM
Yes, it's May, and the exact failure is "Light source and lamp not compatible".
The accompanying guidance states: "Some vehicles may be fitted with High Intensity Discharge (HID) headlamps. It is not permitted to convert existing halogen headlamp units for use with HID bulbs. If it is clear that such a conversion has been carried out, rather than replacing the entire unit with one designed and approved for use with HID bulbs, the headlamp should be rejected".
Personally, and famous last words here, I think we would probably get away with it.. I agree with Tareim above - I think with the projector lenses we won't fall foul of "light source and lamp not compatible". I also hold the (slightly risky) assumption that, to the majority of MOT testers, it may not be "clear that such a conversion has been carried out.."
Fingers crossed anyway!
#8 Tareim
Tareim
  • 80 posts
Posted 05 March 2018 - 11:28 PM
I've got my MOT due in april (1st one with HID swap) so if it passes then I will ask if it's still going to pass the following year in that config and report back (unless someone else can sooner), don't want to ask before hand in case they decided to fail it as a retrofit as they may not know
#9 oblomov
oblomov
    oblomov
  • 3,871 posts
  • Interests:Mumblers
Posted 07 March 2018 - 07:21 PM
So, instead of waiting till the issue is clarified elsewhere (which it inevitably will be) you're going to warn them in advance that your car will perhaps be a fail next time?
Edited by oblomov, 07 March 2018 - 07:22 PM.
#10 Tareim
Tareim
  • 80 posts
Posted 07 March 2018 - 10:59 PM
if it would be a fail next time (which we don't know yet) then it'll give me a year to be prepared to swap the lights around and also let the community know before theirs go in
#11 Madmitch
Madmitch
  • 539 posts
Posted 08 March 2018 - 06:58 AM
I suspect that the problem relates to the legal requirement to have self levelling built into the headlights or the vehicle to avoid dazzle, see below.
    What is examined at the NCT? Roadworthiness testing measures are in place to ensure that the lighting system in a vehicle is in full working order and correctly aligned for the safe performance of the vehicle. Under the European Roadworthiness Testing Directive (2009/40/EC), the National Car Testing Service (NCTS) is required to examine the condition and aim of headlights. This requirement is included in the Road Traffic (National Car Test) Regulations 2014 and is reflected in the NCT Manual. In relation to HID lights specifically, the NCTS checks that:
 A HID bulb, where fitted, is compatible with the headlamp.   The HID headlight assembly (i.e. headlamp and bulb) is fitted with a functioning headlamp levelling system, either manual or automatic. If the vehicle has self-levelling built in to the suspension then this can be considered to fulfil the function of headlamp self-levelling.  The headlamp cleaning device, where fitted, is operating correctly.
#12 vocky
Posted 08 March 2018 - 08:16 AM
aftermarket HIDs are easily recognised by the extra wiring, so will most likely be an instant fail
#13 fiveoclock
fiveoclock
  • 9,453 posts
Posted 08 March 2018 - 09:29 AM
So it only relates to HID? The way forward is LED then. I have good quality LED fitted in my Jeep and they are fantastic, better than any HID I've ever had. I tried some cheaper, probably Chinese LED's and they were rubbish and got very hot. They had a sort of concertina metal mesh cooling system on the back (probably cheap) whereas the better quality ones have a small fan in the back (probably not so cheap)
Edited by fiveoclock, 08 March 2018 - 09:31 AM.
#14 Strugs
Strugs
  • 3,008 posts
Posted 08 March 2018 - 09:35 AM
I think I'm with oblomov.. I'd keep schtum! :lol:
#15 Strugs
Strugs
  • 3,008 posts
Posted 08 March 2018 - 09:36 AM
It's more around muppets fitting HID bulbs to non-projector headlights which cause a dazzling light scatter..
#16 Strugs
Strugs
  • 3,008 posts
Posted 08 March 2018 - 09:37 AM
What would the MOT tester be looking for under the (front) bonnet (genuine question! Not being facetious.. for a change!)?
#17 fiveoclock
fiveoclock
  • 9,453 posts
Posted 08 March 2018 - 09:39 AM
Amongst other things ensuring the battery is secured properly
#18 Strugs
Strugs
  • 3,008 posts
Posted 08 March 2018 - 09:40 AM
I'd be game for giving LEDs a go. Where did you get your current ones from (what brand etc.)? Would the need for having a fan make it a bit tight for space in a VX?
#19 Wolfstone
Wolfstone
  • 12,987 posts
Posted 08 March 2018 - 10:03 AM
I don't think that has ever been checked in 11 years on my MoT on the VX. Even if they've opened the bonnet they've never removed the washer bottle to check the battery.
#20 vocky
Posted 08 March 2018 - 10:10 AM
OEM Xenon lights normally have the ignitors attached to the headlight on moulded fixings, aftermarket HIDs have the ignitors floating about or attached to the bodywork with tape or cable ties.
Pretty easy to spot non OEM stuff
