I've brought one of these, ill test it and let you know how i get on. Hoping to have it fitted for the nationals if anyone wants to have a look or chat about installation etc. The developer has promised to work with me on any issues
Racetcs
#21
Posted 20 April 2018 - 11:46 AM
#22
Posted 20 April 2018 - 11:56 AM
Interested to hear how you get on Richard!
#23
Posted 27 May 2018 - 11:41 PM
Hi,
Whats the difference between this and the RaceLogic traction control ?
#24
Posted 28 May 2018 - 09:43 AM
I bought one last month and fitted it, installation was nice and easy as the instructions are clear and easy to follow. Also the developer is very easy to work with and is very prompt to answer emails.
The system definitely works and is very sensitive, on the lower settings it even picks up the deformation of the rear tyre under hard acceleration. I am still playing around with the settings with the help of the developer as initially I found the cut to aggressive, since I have changed the setting to a lot lower and now it's not aggressive enough. It's just a bit of trial and error as every car is different.
Sent from my SM-G935F using Tapatalk
#25
Posted 28 May 2018 - 03:24 PM
As currently I have a 2nd hand race logic system with no program and no support and all the detailed installation photos on this site have disappeared as they where done so long ago, but it is meant to be a tried and tested system.......
Sent from my LG-H815 using Tapatalk
#26
Posted 28 May 2018 - 04:57 PM
#27
Posted 28 May 2018 - 09:41 PM
Ok thanks, I've just had a read, I think it all looks achievable?!?! Where did you fit it ?behind your passenger seat ?
#28
Posted 28 May 2018 - 09:45 PM
#29
Posted 28 May 2018 - 10:06 PM
Ok thanks
#30
Posted 29 May 2018 - 08:04 AM
It is very similar to the racelogic system in it's operation.
Have you got your water injection turned up to 11?
#31
Posted 29 May 2018 - 08:20 AM
#32
Posted 29 May 2018 - 07:28 PM
#33
Posted 29 May 2018 - 08:21 PM
Email the developer, he must know the answers as its already been fitted to other vx220's
#34
Posted 30 May 2018 - 12:47 PM
Me too! Would love traction control on the tubby. Also not sure what is meant with misfire control disabled? I suppose the oem ecu has this enabled and no way to disable?
A lot of modern ECU's have a function to activate limp / safe mode if the engine experiences consistent misfires, as its assumed such misfires are as the result of a fault.
This type of traction control works by cutting the individual cylinder injector, effectively simulating a misfire which reduces torque. Therefore you need to disable misfire detection / control in order to avoid going into limp mode during activation.
This is can often be done by someone doing a remap (or on NA's using OBD-Tuner, just a click). Maybe try Siztenboots on here who knows the turbo ECU well..
#35
Posted 30 May 2018 - 08:28 PM
#36
Posted 27 October 2018 - 11:50 AM
Here is a DYI guide that we made together with Jon. We took both logos (RaceTCS and VX220.org.uk) as this was a common effort, if there is any objection regarding using VX220 forum logo in the guide, we will remove it.
http://racetcs.com/f...Guide VX220.pdf
#37
Posted 27 October 2018 - 01:09 PM
Do I need to get my exact circumferences loaded into my Dutch software?
Or should I just reference the manual from this point on?
Adam
#38
Posted 27 October 2018 - 02:29 PM
You do not need to modify your Dutch software (maybe disable that misfire detection). Apart from that you can load VX220 presets to RaceTCS. What was identified during install is that stock NA ecu likes to work in full-batch mode during acceleration enrichment, so presets for Turbo and NA for VX220 differ a bit (injection filter for detecting RPM is 3ms , in Turbo 1.5ms is enough)..
When you load the presets, you just setup wheel sizes.
#39
Posted 27 October 2018 - 02:45 PM
Really looking forward to having the security of your system, I'm at Oulton on Tuesday 31st and Silverstone on 5th Nov and no time to fit it, so gutted as it's looking like there's rain about. 😕
I'll have a go at fitting from your very good 'How To Guide 'and feedback anything I didn't understand, thanks again really good commitment on your side,
#40
Posted 27 October 2018 - 04:29 PM
The problem might happen if you put bigger wheels in the back (than set in RaceTCS) and front stays the same. Then rear speed might be smaller by 2-3% , and this will make RaceTCS act later then usually. This can be offset by using 1st setting (1.5%), should still be good in the wet.
