Racetcs
59 replies to this topic
#41 swast4
swast4
  • 416 posts
  • Interests:Trackdays
Posted 27 October 2018 - 05:43 PM
Ok cool thanks
Sent from my LG-H815 using Tapatalk
#42 Gadget2
Gadget2
  • 223 posts
  • Interests:Race & Sprint Marshall
Posted 27 October 2018 - 07:54 PM
For some reason I cannot read the configuration, or download any logging on my laptop running Windows 7.
As the TCS program is fairly new and my laptop is old, do I need to upgrade to Windows 10?
By the way, the unit works extremely well, I'm very pleased with the way that it works on my 220 SC.
Quite chuffed that some of the photos' in the DIY guide is from my car!
Thanks Jacek.
Edited by Gadget2, 27 October 2018 - 07:56 PM.
#43 swast4
swast4
  • 416 posts
Posted 11 February 2019 - 12:59 PM
Hi,
I'm having issues with my TCS
I fitted it last week, went for a drive at the weekend and it didn't work. I've seen some a log and both fronts sensers say it's moving but not the rear wheels.
I've had the wheels off today and disconnected the hub sensors and checked continuity back to the TCS which it has. I have also connected my voltmeter to the hub sensual and spun them by hand and they both give an ac voltage.
I have measured the resistance of the hub sensors and the F/N/S measures 1.4 k ohmes along with the R/O/S. The r/n/s measures 0.6M ohmes. But the speedo is working fine.
I don't know what weeks to check? Do you have any ideas?
Adam
#44 siztenboots
  • 26,613 posts
Posted 11 February 2019 - 01:39 PM
600kohms quite a big difference to 1.4kohm
#45 swast4
swast4
  • 416 posts
Posted 11 February 2019 - 02:05 PM
Yeh I know, but then I have a swerve ball that the speedo works?
#46 swast4
swast4
  • 416 posts
Posted 11 February 2019 - 02:52 PM
Update
I've run an external lead from both rear hub sensors (1 at a time) to the f/n/s (which I know is working) and used the wiring from here. Then had the car on axle stands and the engine running rear hubs spinning, it indicates a speed on the f/n/s. So this is indicating the hub sensors are working.
I've also traced the wires back to the abs loom and measured the resistance on the terminals for the 2 rear hub sensers and they reflect what I am getting at the hub. 1.4k and 600k(i still don't know why this is so high). This would indicate the wiring is fine along with the continuity to the TCS.
I have also reconnected my abs cut off wires and taken it out for a drive but still the rears aren't reading.
I really don't know what else to do??
#47 swast4
swast4
  • 416 posts
Posted 12 February 2019 - 06:06 AM
Update
Next thing I'm trying is swapping the wheel sensors at the TCS, so fronts with rears. This will prove if there is a fault with TCS.
#48 ayresyy
ayresyy
  • 489 posts
Posted 12 February 2019 - 07:31 AM
  Does your ABS normally work?
   If you were a bit closer we could have swapped TCS units to prove/disprove the unit/wiring.
#49 swast4
swast4
  • 416 posts
Posted 12 February 2019 - 03:19 PM
I don't know if the abs is working normally or not ? As I've always had the sensors disconnected on front left and rear right. There was no manual abs cut off switch or wired connections to do the same when I bought it, but the abs light doesn't come on the dash with the ignition. This would indicates that a bulb in the dash was taken out because the abs was not working or it was disconnected (for track use)
Since buying the car and reading such bad things about using the 2 channel abs on track, which is predominantly what I use it for I wasn't fussed.
I have this afternoon, switched the front and rear inputs over at the TCS end. So fronts connected to the rear and rear ones connected to the front.
I then got no signal from the front and a speed reading from the rear. This is indicating that the TCS is functioning correctly. The next thing to try is the other side (non hot side) of the abs sensor. I've been told to pinch the wire and check it is going to earn, we think it gets switched there by the abs module.
I will obviously do the same with one of the fronts that work, just to prove the theory.
I really love cars, but I also really hate them ....................... :angry2:
#50 Exmantaa
Posted 12 February 2019 - 07:01 PM
Did you measure the ABS sensors directly? They should be all ~1400Ohm, which corresponds with your 1.4K measurement...
After that you can measure the individual ABS leads on continuety (0 Ohm) to see where you issue is.
Edited by Exmantaa, 12 February 2019 - 07:06 PM.
#51 swast4
swast4
  • 416 posts
Posted 12 February 2019 - 07:07 PM
I did measure them, which they where all 1.4k apart from the rear left which was 600k. Even though this is measuring so high, it still works as I wired it to the front wheel wiring. It also still works the speedo.
#52 Exmantaa
Posted 12 February 2019 - 10:02 PM
buy a new Astra abs hub instead of swapping F & R... :sleep:
#53 swast4
swast4
  • 416 posts
Posted 12 February 2019 - 11:33 PM
I didn't swap the hub, just ran some extra wires from rear hub to front hub wiring to prove the hub sensor.
#54 turbo boy
turbo boy
  • 1,161 posts
  • Interests:Cars, fitness, fishing, sports
Posted 13 February 2019 - 06:41 AM
Hi Adam,
I would suggest you get the advice of Jacek regarding this. I can put you in touch with him if you haven’t already found him.
Suspect that you used your own wiring?
Jon
#55 swast4
swast4
  • 416 posts
Posted 13 February 2019 - 06:47 AM
Yeh I've been PMing him back and forth, as I try different things.
Regards
Adam
#56 turbo boy
turbo boy
  • 1,161 posts
Posted 13 February 2019 - 07:20 AM
Cool. He’s a wizard 👍
#57 swast4
swast4
  • 416 posts
Posted 15 February 2019 - 07:40 AM
Latest update is.
I think I've fixed it - the problem was a poor connection to the abs module, good enough to give continuity but not strong enough to carry the signal, so very misleading.
I've connected 2 wires in parallel to one of the rear sensors at the hub.
I've connected the hot side directly to the TCS, the other wire is not connected yet.
I've also crimped in a wire to the non hot side of this sensor at the abs module .
I ran car on axle stands and I still had no signal on TCS. I then checked the non hot side by the abs module and it was giving continuity to ground.
I also checked the extra lead that I had connected to the speed sensor and that had continuity to ground.
I then took a lead straight from the battery earth to each of these non hot wires and it would work. I connected the 2 together and it wouldn't work.
This proved that the ground that I got from the abs module wasn't good enough.
I removed the top of the abs module and cleaned all terminals properly with electrical spray and a small spare female fitting, then sprayed them all with brake cleaner to dry it out.
I then did the same with the abs module plug and fitted it all together and it worked on axle stands.
I will take it for a drive today to fully test.
Now that was a long winded job.....
#58 swast4
swast4
  • 416 posts
Posted 15 February 2019 - 07:45 AM
Photos as belowPosted ImagePosted ImagePosted ImagePosted ImagePosted ImagePosted ImagePosted ImagePosted Image
#59 Tolksee
Tolksee
  • 1,197 posts
  • Interests:Naked women
Posted 19 March 2021 - 11:14 AM
Does anybody know a garage in the South of England that can fit RaceTCS?
Nearest to me would be Back On Track or Plans.... Anybody had either of them fit it?
#60 Ivor
Ivor
  • 2,138 posts
  • Interests:Sheep & Ducatis
    and now bees
Posted 19 March 2021 - 12:09 PM
A DIY guide was produced, it's not difficult having seen it done
