Supercharged With Or Without Egr?
supercharged egr mot
12 replies to this topic
#1 PHB1969
PHB1969
    Premium Member
  • 946 posts
Posted 02 May 2018 - 07:40 PM
Quick question when I bought my VX as an NA it had an EGR cheater on it. Its now supercharged and has the same cheater (and a blanking plate over the EGR). - are most people running with a cheater when NA? - are all SC running with no EGR? - as SC with no EGR will this be an MOT fail under the new regs (removal of EGR) - will mapping be affected if I have to retrospectively fit an EGR? (Running CS map not Dutch) Thanks for any input...not looking forward to new MOT regs....
#2 vocky
Posted 02 May 2018 - 07:53 PM
they don't test the egr valve actually works, so bolt one on and add a small section of wiring loom. Just don't bother wiring it to anything :P
#3 VX Mark
VX Mark
  • 174 posts
Posted 02 May 2018 - 07:54 PM
The easiest way is install a blanking plate, then fit the egr valve ontop allowing you to keep it plugged in (so no cheater needed and no EML).
Then it gives the appearance of having a fully fitted and functional EGR, even though in reality its doing nothing  B)
#4 vocky
Posted 02 May 2018 - 07:55 PM
No vx220 SC has a working egr valve, the sc inlet has no connection
If you have a Saab B207 cylinder head or a late z22se cylinder head they don't have the egr mounting, so technically the egr valve is not missing
#5 VX Mark
VX Mark
  • 174 posts
Posted 02 May 2018 - 07:59 PM
Ah yes how could i forget about the SC manifold  :beat:
#6 PHB1969
PHB1969
    Premium Member
  • 946 posts
Posted 02 May 2018 - 08:31 PM
Both, thanks for your input. So the reality is a SC VX cannot have an EGR as there is no connection on the inlet manifold. Presumably job done then....and they cant fail it...
#7 gertje
gertje
  • 459 posts
Posted 03 May 2018 - 05:22 AM
Don't know what software you use but on obd tuner you need just to klik egr off and it's oké to remove it. Save weight Verstuurd vanaf mijn ONEPLUS A3003 met Tapatalk
#8 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 03 May 2018 - 11:55 AM
I cant remember my tester even looking in the boot
#9 PHB1969
PHB1969
    Premium Member
  • 946 posts
Posted 03 May 2018 - 07:45 PM
New MOT regs coming in.....
#10 Mat Jackson
Mat Jackson
  • 1,579 posts
Posted 03 May 2018 - 07:51 PM
I know - but will they really look? Sent from my iPhone using Tapatalk
#11 pete-r
pete-r
  • 2,771 posts
Posted 04 May 2018 - 09:44 AM
No I can't see it being workable. Imagine you have a boxster or an Audi A2 - you can't even see the engine!
#12 oakmere
oakmere
  • 2,143 posts
Posted 04 May 2018 - 09:18 PM
I mentioned the new MOT regs to my local tester last month and they havent been informed of the changes yet. I wouldnt worry about it too much.
#13 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 11 May 2018 - 11:10 AM
Most of them will do things like putting the emissions tester in the back of someone else's car when your VX won't pass :ninja:
obviously they know the cars they should be keeping on the road :D
Also tagged with one or more of these keywords: supercharged, egr, mot
