I can make/supply stiffer engine side mounts that are 2.5 times stiffer than the OEM mounts and more robust. The OEM side mounts are prone to failing pretty rapidly (particularly on the gearbox side) as the metal cap tends to shear away from polyurethane/rubber. The way mine are made ensures several bonding platters for the polyurethane to "key" into, so unlike the OEM ones they are considerably more resilient to shearing and breaking apart.
My mounts are a direct swap for the OEM parts (both NA and Turbo models) and will stop your engine from rocking around so much. This will likely:
1. Improve gear change slickness (it did on mine) as the gearbox cables aren't being moved around so much.
2. Reducing how much the exhaust tips move about and how much strain the flexis have to take.
3. "tighter" feedback about what the car is doing at the rear, this is genuinely noticeable.
4. More direct clutch engagement feedback (ie less soggy feeling).
I can supply fitting instructions with them if you need. You only need a few simple tools and it takes about 45 to 60 minutes per side, maybe 90 mins to fit your first one if you are new to the car.
IMO these compliment the yellow rubber inserts that go into the front + rear engine mounts well, as they are similar in stiffness. With the yellow front+rear mounts and my side mounts installed you can expect the engine to reduce rocking from around 25mm to around 7mm (which is a bit torque/gear dependent though).
£65 each + postage (which is about 1/2 of the cost of the Vibratechnics ones).
Edited by Nev, 31 May 2018 - 11:08 AM.
