Chipex
3 replies to this topic
#1 fiveoclock
fiveoclock
  • 9,453 posts
Posted 25 June 2018 - 05:46 PM
Anyone used Chipex. Looks like withcraft to me
https://www.chipex.co.uk/
#2 pete-r
pete-r
  • 2,771 posts
Posted 25 June 2018 - 06:51 PM
No top coat in that so will be soft unless it's pre mixed in which case it's clever stuff.
My method has always worked well in the past.
Just use a normal touchup stick but mix it with a little clearcoat in a plastic cup and apply it super thin with a cocktail stick. It's closer to gelcoat when dry. If you want it 100% do the colour step then go back over with clear, repeating the next parts twice.
Get some sticky back wet sand paper from Amazon and press out a circle using a hole punch.
Stick it to the top of a wooden pencil (not one with a metal collar) and work the paper over the paint to flat it down by twisting the pencil in your hand. When your happy with the flattened finish polish with a DA.
If the colour match is right you'll never even know it's been repaired.
Edited by pete-r, 25 June 2018 - 06:53 PM.
#3 Atom
Atom
  • 28 posts
Posted 08 July 2018 - 04:26 PM
pete-r - yes that’s how I’d have done it. Any luck in the chipx?
#4 Atom
Atom
  • 28 posts
Posted 08 July 2018 - 04:31 PM
