Max Side Air Intakes
151 replies to this topic
#1 MAXR
MAXR
  • 2,719 posts
Posted 06 August 2018 - 07:43 PM
Ok, I thought I would separate the Max Coupe Back conversion from the Max Side air intake conversion.
Good News First. This conversion will be fine with standard windows & runners. The door bar is unaffected & so is the locking mechanism.
I now have paper & CAD templates for all cuts required to produce this conversion which I’m happy to send anyone if they want to do the same. I’m also happy to supply ones for the coupe back, once it’s completed.
So far, I have spent a total of 3.5 hours on this side so far. Now that I have templates, I honestly think that it can be done in 1.5 hours per side with the rear clam off.
I’m genuinely pleased with the results, I guess everyone will have an opinion, which is the way it should be! So no problems if anyone thinks it’s hideous or just sh1t, I’m ok with that!
The photos below show progress this evening. It looks a nice conversion, Because it’s in keeping with the car’s design.
1D39A99F-56F5-4C3D-8CFE-12167EF4CBE5_zps
67BEA98C-BC6D-479A-8348-4F5FBDB1E553_zps
285A841B-E18B-43BF-8DDC-465847863D31_zps
2835C279-4438-4FDE-BE83-2CE97ED95417_zps
5004AEDC-1C9F-437F-A559-0DC876316E22_zps
406565D5-F552-46AB-BE15-6227A2FADA58_zps
7736EB7F-B76C-402C-AFF6-1FCA940715D0_zps
C5A592E0-67A3-47E0-923A-6E56D5F66B02_zps
5CF2FDDF-9C77-400D-9232-BEFA6896323C_zps
#2 Curtiscraddock
Curtiscraddock
  • 328 posts
Posted 06 August 2018 - 08:19 PM
Love it
#3 oakmere
oakmere
  • 2,143 posts
Posted 06 August 2018 - 08:23 PM
Very similar to the Lotus Europa 👍.
#4 Duncan VXR
Duncan VXR
  • 5,281 posts
Posted 06 August 2018 - 08:52 PM
Looks great Max and touch of reverse 2-11 front door / clam
Well done
#5 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 06 August 2018 - 08:58 PM
Not sure the fixings will hold up beyond 120mph - you really need genuine DUCK tape for those kind of speed. I've heard the Lotus boys use Gorilla Glue Cloth but frankly it's twice the price and does the same job. You pays your money...
#6 MAXR
MAXR
  • 2,719 posts
Posted 06 August 2018 - 09:10 PM
My car used to be held together with duck tape for real. My gearbox oil catch tank upto very recently used to be a coke can!
#7 chris_uk
Posted 07 August 2018 - 12:12 AM
i did have a sprite one, but i upgraded to diet coke.  :)
37579772_10156490321872731_5477336165835
#8 Nev
Posted 07 August 2018 - 05:23 AM
If you take your floor pan + "diffuser" off under the engine you'll get a massive cooling effect, and IME it make next to no difference to aerodynamics at the sorts of speed one does on track. Also a 6 Kg weight reduction (at the rear where it's important). Worth considering?
Edited by Nev, 07 August 2018 - 05:25 AM.
#9 MAXR
MAXR
  • 2,719 posts
Posted 07 August 2018 - 05:44 AM
Nev,
I have noted that you have mentioned this on a few occasions. I’m considering getting rid of my rear diffuser as I run my car quite high & I don’t think it does jack. If I do, I may ditch my large rear tray.
#10 Nev
Posted 07 August 2018 - 07:01 AM
Yep, even flat out for 1 minute at 6 to 8,000 RPM my water temps stay below 92 degrees, and thats when making 400 to 520 HP roughly, so tons and tons of heat.
I went round Llandow in the summer, which Im sure you know is a tiny track, so speeds barely touch 100 MPH and you get limited ram effect on the rads. But even there my water temps didn't get above 90 - which really surprised me. I only have the Pro-alloy rad and pre-rad same as everyone else.
Getting a scoop on the front/top of the roof feeding air to the engine has got to help too.
HTH & GL.
Edited by Nev, 07 August 2018 - 07:03 AM.
#11 MAXR
MAXR
  • 2,719 posts
Posted 07 August 2018 - 07:10 AM
I will try it with & without trays when I'm next out. Any additional genuine cooling is worth way more than questionable untested aero props.
#12 MAXR
MAXR
  • 2,719 posts
Posted 07 August 2018 - 07:47 AM
I think FLD was completely correct, looking at the door intake this morning, I also concur that the door scoop should be taken right down to the bottom of the door, allowing the sill to become the base of the scoop. It will also allow for where the bottom of the scoop enters the engine bay to be curved upwards to become a canyard aero thingy?
This would greatly simplify the conversion & look more cohesive. I also intend to lose the side pods in favour of a more standard NA look. The new area for the air to enter the engine bay will have more than doubled.
#13 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 07 August 2018 - 10:57 AM
Great idea and i think will look very nice when finished impressed .
#14 Dan r
Dan r
  • 666 posts
Posted 07 August 2018 - 05:06 PM
Looking forward to seeing this all finished, should look great and actually do something for the performance for a change.
Good work
Sent from my G8441 using Tapatalk
#15 mafumoto
mafumoto
  • 123 posts
Posted 07 August 2018 - 06:01 PM
Very interesting idea
#16 2-20
2-20
  • 1,317 posts
Posted 07 August 2018 - 06:05 PM
It reminds me this :
https://www.dailymot...m/video/x5rrrl5
#17 Ivor
Ivor
  • 2,139 posts
  • Interests:Sheep & Ducatis
    and now bees
Posted 07 August 2018 - 06:19 PM
Must be good, this article came up in my Google news feed today :)
#18 MAXR
MAXR
  • 2,719 posts
Posted 07 August 2018 - 06:52 PM
Even though I honestly have not checked to see what people have done in the past, my solution was born out of the need to produce a simple effective solution that looked like a factory design detail. It would have been easy to graft on a roof scoop or snorkel? Lol.
That said, rarely does someone come out with a brand new idea. I have not! But, this solution is relatively cheap, easy to modify and functional plus I think it suits the car.
#19 hairy
hairy
    Moonlander
  • 6,019 posts
Posted 07 August 2018 - 07:12 PM
Not entirely sold by the look, but well done for trying something new. Do the windows still wind down?
#20 MAXR
MAXR
  • 2,719 posts
Posted 07 August 2018 - 08:16 PM
Yes, all internals unchanged
