Edited by chris, 08 August 2018 - 04:34 AM.
Posted 08 August 2018 - 06:32 AM
Posted 08 August 2018 - 09:30 AM
Posted 08 August 2018 - 10:13 AM
Posted 08 August 2018 - 03:18 PM
Edited by Talk-torque, 08 August 2018 - 03:19 PM.
Posted 08 August 2018 - 04:09 PM
Posted 08 August 2018 - 04:14 PM
Posted 08 August 2018 - 04:54 PM
Iirc winstar did some flow calculations and found the scoops very inefficient, it wasn’t that they weren’t big enough but the air just wasn’t really getting to them.
I’m guessing the airflow is detaching round the front wheels and arch, I’m wondering if canards could be used on the front corner to energise the airflow by creating a vortex which should help it stay attached to the side of the car. This should increase the volume of air actually getting to the scoop.
This of course could all be bollocks and with any luck winstar will be along to show me how wrong I am
Posted 08 August 2018 - 04:58 PM
You could well be right, it was some time ago and I’ve had a few drinking sessions with Joe since so the memory ain’t what it used to beI'd thought it was down to the lack of ducting / directing surfaces once inside the vent. Which, to be fair, is non-existent in my car. I'm sure winstar will be along to enlighten all.
Posted 08 August 2018 - 05:13 PM
Edited by 2-20, 08 August 2018 - 05:20 PM.
Posted 08 August 2018 - 05:19 PM
It reminds me this :
https://www.dailymot...m/video/x5rrrl5
Even though I honestly have not checked to see what people have done in the past, my solution was born out of the need to produce a simple effective solution that looked like a factory design detail. It would have been easy to graft on a roof scoop or snorkel? Lol.
That said, rarely does someone come out with a brand new idea. I have not! But, this solution is relatively cheap, easy to modify and functional plus I think it suits the car.
I fully agree with you ...
I was just wondering if you had seen it before....
The guy has shown his modifications on this forum but they were not very well received despite a few good ideas....
Posted 08 August 2018 - 05:45 PM
love it!
i still think you will be slow though
Posted 08 August 2018 - 06:06 PM
Posted 08 August 2018 - 06:18 PM
dont worry, my hair is already turning silver
Posted 08 August 2018 - 06:34 PM
Really nice mod.
I had the same idea and wanted to do it this winter ! You've been faster than me !
I will follow your topics with care ! (your coupe back topic is also very interesting)
I hope you will put a lot of pics.
Posted 08 August 2018 - 07:08 PM
Posted 08 August 2018 - 07:32 PM
Posted 08 August 2018 - 08:53 PM
Ok, the latest update from this evening.
Its hard to see the effect with the black doors.
Good points:
This variation tapers the entire door below the swage line and Looks less fussy.
No cables, pipes come anywhere near the area being modified.
Most of the high-density foam is retained in the main pillar.
There is plenty of space behind the door to make the opening 60mm wider by removing more foam.
I will be making the flat top of the sill curve upwards behind the door to give a canard effect & to sweep the air up & into the engine bay. Possibly having a nacca style pipe take off like this to allow air to be taken to my gearbox/sc etc
Photos with & without CF side pod. I think a custom one with mesh grills may look better.
The handle to open the door on the underside of the lock will work beautifully & be hidden from sight. The old recess will be rotated through 90 degrees to locate your fingers in.
The lock protection plate inside the door had to be cut down, but it is retained & will continue to do it's job.
This conversion is purely cosmetic & only alters the fibreglass sills & door. No brackets or metal cutting is involved.
Posted 08 August 2018 - 08:55 PM
Ive been thinking of colour schemes....
I may go for Audi Nardo Grey main colour with Viper green side scoops, roof & coupe back & matt black wheels. What do you think?
Posted 08 August 2018 - 08:56 PM
FFS not another primer coloured car.
Max i thought you had more taste than this.... youve disapointed me
