Tcs Traction Control System - All Model
219 replies to this topic
#141 Rosssco
Rosssco
  • 4,183 posts
Posted 08 October 2018 - 10:34 AM
Hi Jacek,
Would your system work on an Elise 111r?
Hi
The system should work with any car that has multipoint (no direct) injection. ABS systems are almost all identical (there are just 2 types of wheel speed sensors). I see no reason why it should not work.
Direct injection cars might get suitable hardware next year.
For future discussions please use this topic :  http://www.vx220.org...-racetcs/page-2.
Jacek
That would be an interesting development :)
#142 MartynM
MartynM
  • 44 posts
Posted 09 October 2018 - 11:38 AM
Hi Martynm,
Ok,
sh*t happens. I guessed there would be some cancellations. I just hope we can make it still worth Jacek’s time flying from Poland for us...
I will work something out for your system, no worries. Will most likely arrange delivery myself as all the items have successfully been delivered to RLM now.
We are all good for that weekend now guys 👍
Tell me about matey, I wasn't best please to say the least, just sorry to mess things around a bit.
Thanks Jon, pm when you need address details etc.
Updated;
• Fri  - Turboboy - Test Fit.
Sat Opening times 9-2PM
•9AM - Ash_gt4 (PAID)
•11AM - Di3sel (PAID)
•1PM - Nev (PAID)
•3PM - Titan (PAID)
•5PM - Ayresyy (PAID)
Sun Opening times 9-5PM
•9AM - Rabbidog (PAID)
•11AM - Gadget2 (PAID)
•1PM - Available Slot?
•3PM - Deano01 (PAID)
•5PM - Ivor (PAID)
DIY:
•Matt555
•Swast4 (PAID)
•MartynM (PAID)
#143 Ivor
Ivor
  • 2,140 posts
  • Interests:Sheep & Ducatis
    and now bees
Posted 09 October 2018 - 06:02 PM
I'm happy to take the earlier slot if jakec wants an earlier finish
#144 turbo boy
turbo boy
  • 1,161 posts
  • Interests:Cars, fitness, fishing, sports
Posted 10 October 2018 - 05:45 PM
Hi Ivor,
It’s yours my friend.
I would be grateful if you could update the list as I cannot do this on my phone.
Thanks,
Jon
#145 Ivor
Ivor
  • 2,140 posts
    and now bees
Posted 11 October 2018 - 05:42 AM
Thank you, updated
Updated;
•1PM - Nev (PAID)
•3PM - Titan (PAID)
•1PM - Ivor (PAID)
•5PM -
DIY:
•Matt555
•Swast4 (PAID)
.MartynM (PAID)
Edited by Ivor, 11 October 2018 - 05:43 AM.
#146 rabbidog
rabbidog
  • 194 posts
Posted 11 October 2018 - 07:17 PM
To save time I was going to remove the seat, handbrake cover and rear panel and leave it all at home. This will also give better access all around.
For anyone with limited mechanical knowledge it's fairly easily.
Passenger seat is 4 bolts, one at each corner and the seat belt mount, one bolt.
Rear plastic is plastic screws all easily accessible
Hand brake cover is two screws each side, two grubs on handbrake handle then just slide it off
Any ideas how best to access/remove the front passenger bolt nearest the door?
#147 oggster
oggster
  • 886 posts
  • Interests:Staying alive 😉
Posted 11 October 2018 - 07:28 PM
I used a cut down Allen key..
#148 ash_gt4
ash_gt4
  • 89 posts
Posted 11 October 2018 - 08:34 PM
I used one of these
https://rover.ebay.c...tm/182706260633
#149 rabbidog
rabbidog
  • 194 posts
Posted 11 October 2018 - 08:46 PM
I used one of these
That looks worth buying.
I assume the only way is to remove the seat and frame together via the 4 bolts, rather than detach the seat from the frame in situ?
#150 Nev
Posted 12 October 2018 - 04:17 PM
Hi,
May I ask why people are taking their handbrake cover/faring off - is it just so the potentiometer can be mounted onto the cover/faring, or is there some other reason?
I ask, as I already have a mounting point for the pot on my DIY dashboard.
Thx.
Edited by Nev, 12 October 2018 - 04:18 PM.
#151 Gadget2
Gadget2
  • 223 posts
  • Interests:Race & Sprint Marshall
Posted 12 October 2018 - 06:39 PM
I may be wrong (often!) but my understanding is that if one requires the handbrake light on the dashboard to show the level of slip, then access to the wiring can be taken direct from the handbrake switch.  This is why the centre cover is removed. The  positioning of the pot can also be put there, but Nev, I can see no reason why it could not be put into your dashboard; also a led to indicate the level of slip may be used instead of the handbrake light.
However, even though I've taken all the fixings out from my back panel, it refuses to move,  I do not want to force it too much and risk splitting  it.
Edited by Gadget2, 12 October 2018 - 06:43 PM.
#152 RaceTCS
RaceTCS
  • 35 posts
Posted 12 October 2018 - 06:51 PM
Hi
Handbrake cover needs to go off to have slip indication on handbrake light. If you are fine with a LED somewhere in your DIY dash, then taking this cover is not needed....but i was instructed it is wise to remove it to route the wires under the cover.
Jacek
#153 Nev
Posted 13 October 2018 - 01:17 AM
Hi
Jacek
Thx for the update. :)
#154 turbo boy
turbo boy
  • 1,161 posts
Posted 13 October 2018 - 07:10 AM
This time next weekend people 🤪....
I will be unable to join you on the Saturday but will drive Jacek up on the Friday night to his Hotel and look forward to seeing those attending on the Sunday 👍
#155 rabbidog
rabbidog
  • 194 posts
Posted 14 October 2018 - 06:17 PM
Are we agreed the rear plastic bulkhead panel behind the seats that the speakers fit to needs to be removed?
Edited by rabbidog, 14 October 2018 - 06:22 PM.
#156 rabbidog
rabbidog
  • 194 posts
Posted 15 October 2018 - 11:22 AM
While on the phone to courtenays this morning I mentioned having a RL type traction control system fitted soon,  they said that in the past they have had to remap a number of cars with RL systems due to random cylinder misfire codes being thrown up. and having to map them out to above 9000 RPM
Is this likely to cause issues?
#157 RaceTCS
RaceTCS
  • 35 posts
Posted 15 October 2018 - 11:50 AM
This is the same story as RaceLogic. All of you who haven't yet read the manual, please do :). Better not to have surprises like this one, when it is stated in the manual ;).
http://racetcs.com/f...User manual.pdf
Jacek
#158 Rosssco
Rosssco
  • 4,183 posts
Posted 15 October 2018 - 12:55 PM
Jacek
Yep, 1.c refers to 'misfire detection'.
For those using OBD-Tuner with their supercharged engine, you just have to select the option on the drop down menu to disable (normally disabled anyway I believe).
#159 Di3sel
Di3sel
  • 125 posts
Posted 15 October 2018 - 03:15 PM
Jacek
Do you know if the Turbo ones have this or no?
#160 ayresyy
ayresyy
  • 489 posts
Posted 15 October 2018 - 03:30 PM
  If you mean misfire protection, then yes they do.
I am not sure if this will be an issue for everyone with a tubby running the standard ECU/map or not, but a minor tweak to the map should be able to rectify things if it becomes an issue.
